Wrong resistor in SoundLab Plus
Page 1 of 1 [3 Posts]
Mesir1
PostPosted: Fri Jan 28, 2011 4:02 am    Post subject: Wrong resistor in SoundLab Plus Reply with quote  Mark this post and the followings unread
Hello.
I`ve just finished my SoundLab Plus, and as I turned it on, there was no sound. None, not even a spark or hiss or...well, there was silence.
Checking the pcb, I discovered that R89 was 2M, and not 200K as it`s supposed to be. Could this cause the problem? And could it cause other problems as well, like damaged components?
RubberSound.
RF
Audio files: 28
PostPosted: Fri Jan 28, 2011 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
R89 - in the LFO section. Not likely to be the cause of your problem, and I can't imagine you hurt anything.
If it does nothing at all, check your power supply connections and switching first.
After that, the most likely issue if you have NO sound would be output jack wiring or other 'flying wires' to pots, switches and jacks.
Check for solder 'bridges' - unintentional blobs of solder on the underside of the board.
Check IC orientation, and correct polarization of capacitors.
Good luck!
bruce
www.sdiy.org/rfeng
John Noble
PostPosted: Sat Jan 29, 2011 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll add one of my own favorite goofs to the collection: if you used IC sockets (a very good idea), make sure you didn't squish the IC's legs under the chip package or otherwise mis-install something.
