Knob Sequencer
Page 1 of 1 [3 Posts]
Sinuosity
G2 patch files: 11
PostPosted: Mon Mar 07, 2011 5:20 am    Post subject: Knob Sequencer
Subject description: 2-Line
Hi. This is my Semi-Auto Mono-sequencer. There is 2 lines of notes. Each line contents triggers & pitches.
The triggers (Red Section) main controls is: Quantity, Pattern, Rate, Phase (start position).
The pitch(yellow section) main controls is: Pattern A&B , Range, Level.
Pitch Modulation (GreenSection) controls: Low Value, WaveForm and shape, Range, Rate, Phase, Notes.
Main Position (Blue module) is shifting the start position of all sequence via Phase knob.
If triggers of line 1 & line 2 trigs together at the same time the line2 will ignored.
Load to Slot B
The User can control this sequencer with only few knobs and buttons from MIDI controller.
Enjoy! Have a nice Day!
Semi-Auto Seq ver 2.pch2
 Filename:  Semi-Auto Seq ver 2.pch2
 Filesize:  5.06 KB
 Downloaded:  4103 Time(s)
Chrisi
G2 patch files: 9
PostPosted: Mon Mar 07, 2011 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice Patch, thanks for sharing Exclamation
Sinuosity
G2 patch files: 11
PostPosted: Tue Mar 08, 2011 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image, might have been reduced in size. Click Image to view fullscreen.[/img]
