GrandJu
Joined: Jul 04, 2010 Posts: 32 Location: Rennes France
Posted: Mon Apr 25, 2011 4:16 am Post subject:
Chord generator class |
Here is a class I coded to generate chord. I am not a solfege specialist, I get chords description in wikipedia, so if important chords are missing or if there are some errors, please advise me.
Use this public class in another chuck file or simply uncomment example at the end of the file.
Have fun
Ju
Code: |
public class chord{
6./5.=>float minor_third;
5./4.=>float major_third ;
3./2.=>float perfc_fifth ;
64./45.=>float dimin_fifth ;
8./5.=>float augmt_fifth;
5./3.=>float dimin_sevth ;
9./5.=>float minor_sevth;
15./8.=>float major_sevth;
//float perfc_elevn ;
//float major_thirt;
Gain input;
input => Gain third_u;
input => Gain fifth_u;
input => Gain seveth_u;
1=> input.gain;
0=> third_u.gain;
0=> fifth_u.gain;
0=> seveth_u.gain;
fun UGen fondamental (UGen @ in){
in => input;
return input;
fun UGen third (){
return third_u;
fun UGen fifth (){
return fifth_u;
fun UGen seventh(){
return seveth_u;
fun void set_chord(int num){
if (num == 0){
// reset chord
0=> third_u.gain;
0=> fifth_u.gain;
0=> seveth_u.gain;
else if (num == 1){
//Major triad
major_third=> third_u.gain;
perfc_fifth=> fifth_u.gain;
0=> seveth_u.gain;
else if (num == 2){
//Minor triad
minor_third=> third_u.gain;
0=> seveth_u.gain;
else if (num == 3){
//Augmented triad
augmt_fifth=> fifth_u.gain;
0=> seveth_u.gain;
else if (num == 4){
//Diminished triad
dimin_fifth=> fifth_u.gain;
0=> seveth_u.gain;
else if (num == 5){
//Diminished seventh
dimin_sevth=> seveth_u.gain;
else if (num == 6){
//Half-diminished seventh
minor_sevth=> seveth_u.gain;
else if (num == 7){
//Minor seventh
else if (num == 8){
//Minor major seventh
major_sevth=> seveth_u.gain;
else if (num == 9){
//Dominant seventh
else if (num == 10){
//Major seventh
else if (num == 11){
//Augmented seventh
else if (num == 12){
//Augmented major seventh
else {
<<< "Invalid chord number">>>;
/* Chords number
0 reset chord
1 Major triad
2 Minor triad
3 Augmented triad
4 Diminished triad
5 Diminished seventh
6 Half-diminished seventh
7 Minor seventh
8 Minor major seventh
9 Dominant seventh
10 Major seventh
11 Augmented seventh
12 Augmented major seventh
//Step input;
//Std.mtof(64) => input.next;
//chord chord_1;
//input => chord_1.fondamental => TriOsc s0 => ADSR ad => LPF filt =>NRev rev => dac;
// chord_1.third() => TriOsc s1 => ad;
// chord_1.fifth() => TriOsc s2 => ad;
// chord_1.seventh() => TriOsc s3 => ad;
//chord_1.set_chord(8);
//rev.mix(.05);
//Std.mtof(89) => filt.freq;
//ad.gain (0.1);
//ad.set (1::ms,3::ms,0.8,50::ms);
//while (1){
//ad.keyOn();
//200::ms => now;
//ad.keyOff();
//400::ms => now;
frank discourse
Posted: Tue Jul 12, 2011 6:50 pm Post subject:
re chord gen Subject description: impressed but still confused |
Hey GrandJu,
I uncommented the lower part of your chord gen as you advised
but am still a novice in progress as you know so I was not clear on how to enter the auto chord numbers to generate progression as i believe the script should do. Can you tell me how to do this?
I am at a stage with ChucK now where I really want to accelerate my skills but am feeling at a disadvantage to many of the people on the forums who are very familiar with similar coding environments.
Would you advise reading up on Java or Python to help with overall understandings to using the ChucK language? For example I need to understand the idea of 'public classes' and creating functions more.
What do you think would help?
My current strategy is scouring the web and examining other peoples code when I hit a problem I can't solve but solutions aren't always available to my level of understanding.
At the moment I am trying to get midi cc control into ChucK from a BCR2000.
It shows up in some of the example scripts correctly and sends encoder info but i'm having trouble translating this to parameter control.
if(msg.data1==176&&msg.data2==81)
msg.data3/100 => r.mix;
this is an example of how i'm trying to do this, i'm sure it is not a sensible way, where can I find info on this?
Thanks in advance for any directives Frankie_d |
GrandJu
Posted: Mon Jul 18, 2011 1:06 pm Post subject:
Hi Frankie_d,
This example is just playing one chord at a time. There is no progression.
If you want to do so, try to change the base note (Std.mtof(64) => input.next; ) or the chord type (chord_1.set_chord(8);) in the loop.
To improve your coding skills I advise you to read some course or tutorial on the web (C, C++, JAVA...). And of course read the Chuck_manual.pdf and examples provided with the program.
Concerning your midi control, I think it didn't work as you want because variable are computed as integer. You can use "cast" to force your computer to compute floating numbers:
Code: |
(msg.data3 $ float) / 100. => r.mix;
<<<"r.mix",r.mix>>>
And don't hesitate to add print message ( <<< >>> ) to know what is realy computed in your script.
Have fun!
Ju |
