ARP Odyssey MKII/III VCO - Eurorack Format
Page 5 of 5 [122 Posts]
Goto page: Previous 1, 2, 3, 4, 5
furio
PostPosted: Sun Aug 25, 2013 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
My new HiFi version sounds amazing.
 Filesize:  119.18 KB
 Viewed:  961 Time(s)
PostPosted: Sun Aug 25, 2013 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is the switching lug used for something else? If not, you could add a ground connection to it, was my point. Then you don't have to worry about the position of the attenuator, input will be always grounded unless there's a jack inserted.
furio
PostPosted: Sun Aug 25, 2013 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks for the advice! I was inspired by the Andy's PCB and he had not used the switch.
P.S. Gnd is on the vertical and the switch is not used.
 Filesize:  102.42 KB
 Viewed:  36368 Time(s)
 Filesize:  35.19 KB
 Viewed:  836 Time(s)
isak
PostPosted: Fri Sep 06, 2013 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
ive never saw pink resistors before, cool.
are they 5%?
furio
PostPosted: Fri Sep 06, 2013 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
are they 5%?
no, the pink are 2% carbon film by Takman... many of the values are more accurate than most 1% metal film.
isak
PostPosted: Fri Sep 06, 2013 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info.
I got one question about this vco..
I have a small issue with the scale.
When turning the vco on and play C2 it plays C2 but with +20 cents, after 5 min or so it stable on center of C2, any ideas why its like that?
The Tempco is between the 3906 and 3904 with thermal Gris, really don't know why it's acting like that.
Do I really need to wait for the vco to worm up?
Strange, don't you think?
Cheers.
furio
PostPosted: Fri Sep 06, 2013 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers.
You're welcome!
I noticed that with certain metal film resistors least 10-50ppm and 0,1-1% improves stability and decreases the tracking error... at the moment I have a stability of +/-1% and a scale error of +/-3%... this vco module out of the rack, needs 45 minutes of heating and the window must be closed. I have not yet tried to put on Tempco thermally conductive materials. To reach these performance due I install a silver mica 680pf and it still sounds even better than styroflex.
for better stability: R53 (Roederstein Resista 50ppm / 150K) & R60 (Beyschlag 50ppm / 100K)... for better sound: carbon film R61(12K) & R62(1K2)
 Filesize:  69.83 KB
 Viewed:  858 Time(s)
isak
PostPosted: Fri Sep 06, 2013 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
I used 1% resistors in the vco, the caps are all wima polypropylene.
It's sound amazing but I have this irritating drift when turning it on.
I guess I have to live with that..haa
45 min? Its damn long to wait for play, LOL.
wander what kind of resistors ARP used in the ody synth.
paulstone
PostPosted: Wed Sep 18, 2013 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello guys Smile
for this VCO it is possible to use the array CA3046 instead of the CA3086 ?
the CA3046 i have to much in home , for the CA3086 is difficult to find
thx !
Paolo
isak
PostPosted: Wed Sep 18, 2013 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Smile
Yes, you can use them, they work great.
paulstone
PostPosted: Wed Sep 18, 2013 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
isak wrote:
Hello Smile
thanks Isak for your fast info Smile
noiselector
PostPosted: Wed Feb 12, 2014 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I have built a two of them but one gets a lower pitch than the other one even adjusting the freq trimmer to maximum.
Any help?
robboten
PostPosted: Sat Feb 15, 2014 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi. Just built this lovely thing. Love the PCB-layout btw! It's beautiful! I use 12V euro and just read about the PW resistor mod and will use that. Otherwise everything as in first post, except 5906 instead of 5910 and 5457 instead of 5459.
Another thing thats bothering me a bit is the range of the Coarse Freq pot. Without V/O CV (keyboard) I get about 15Hz-70Hz by turning the pot. With Keyboard plugged - C2 as lowest and upwards so far as my keyboard goes. If I tune it up to have higher Hz without keyboard, the lowest note is too high with the keyboard. Is there a way to increase the Coarse freq pot range or is there anything fishy about this? Also - the coarse freq pot is in reverse. If I turn it up the freq goes down... Otherwise everything else is great. Any ideas?
furio
PostPosted: Tue Apr 29, 2014 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Odyssey's Ring Modulator: 22K, 22K, 100n, 150K, 150K, 5K6, 2N3904, 1N4148, 330K, 1N4148, 150K (back), 150K.
 Filesize:  507.36 KB
 Viewed:  703 Time(s)
mono-poly
PostPosted: Sat May 31, 2014 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Isn't the 270K resistor which is connected to VCO1 Freq trimmer suposed to connect to something?
Question
mono-poly
PostPosted: Sat Jun 21, 2014 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
anyone???
robboten
PostPosted: Tue Jun 24, 2014 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Found my error. It was a small gap in my home made PCB, as usual. The negative Voltage didn't reach the pots. So simple, but yet so common. Now I'll just tune it again.
bamboombaps
PostPosted: Tue Aug 30, 2016 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
may the lord forgive me for bringing this necro thread back to life, but i could really use on the of the panels if anyone has one?
supercolio
PostPosted: Mon Mar 20, 2017 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi! I wonder if anyone reads this thread, but can someone measure voltages from working unit, I built one and as of yet it doesn't oscillate, or make any noises as a matter of fact. I have ordered new chips so I'll try those too... Thanks!
JP8
PostPosted: Mon Mar 25, 2019 5:18 am    Post subject: Jacks for the Ring Mod PCB Reply with quote  Mark this post and the followings unread
I got the panels and PCBs from Pusherman in the UK. I'm wondering what jacks to search for for the Ring Mod since I haven't been able to find me a BOM for this little module. I'll include a picture of the PCB I purchased.
What kind of jacks to use here? (5-pins?)
Any help would be appreciated.
Ricardo
 Filesize:  3.12 MB
 Viewed:  429 Time(s)
Cathmart
PostPosted: Tue Apr 09, 2019 9:55 pm    Post subject:  Arp Odyessy - PCB Pusherman 2019 Reply with quote  Mark this post and the followings unread
Hi...any help with the parts layout for the Current ARP Odyessy VCO sold on Pusherman.....it is SIGNIFICANTLY different to the pcb info here.
thanks
sorry attachment went twice....
 Filesize:  1.11 MB
 Viewed:  427 Time(s)
 Filesize:  1.11 MB
 Viewed:  414 Time(s)
icnagy
PostPosted: Wed Apr 10, 2019 3:18 am    Post subject: Re: Arp Odyessy - PCB Pusherman 2019 Reply with quote  Mark this post and the followings unread
Hi Cathmart,
I think you're looking for this repo: https://github.com/PhilicityK/ARP_Odyssey_VCO
thanks
