 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Schmaltz Machine
Page 1 of 1 [2 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Jan 19, 2013 3:33 pm    Post subject: Schmaltz Machine
Subject description: Automatic emotion
This started off as a building block that would produce 4 note values that would not be closer to each other than a preset minimum.
The 4 rndclk modules have their outputs monitored and if the absolute difference between any notes is less than the MaxDistance level, a bank of OR gates injects more pulses (at 48K) into the rndclk till all the outputs conform.
I added some pairs of value switches in column 1 to do a sort (sort of) of the resulting notes.
Coupled with a DX7 piano and a pad for maximum Twisted Evil effect.
schmaltzMachine.prf2
Automatic emotion
 Filename:  schmaltzMachine.prf2
 Filesize:  11.22 KB
 Downloaded:  4738 Time(s)
PostPosted: Sat Feb 09, 2013 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Lovely... sunny
