Lorenzo
Joined: Nov 09, 2008 Posts: 375 Location: Trieste - Italy
Posted: Mon Feb 10, 2014 11:59 am Post subject:
I need a very simple mixer |
I need a simple mixer to mix 2-3 mono lo-fi audio signals.
I need 2-3 line input and the chance to adjust the output volume.
maybe 9v battery...
can you suggest me some schematics?
Actually I made a bodge solding 2 cables in one ouput... it works but...
Thank you! _________________ Yes!
Oh Yeah!
Wow! |
Lorenzo
Posted: Mon Feb 10, 2014 12:38 pm Post subject:
Re: I need a very simple mixer |
PHOBoS wrote: | You might be able to get away with a passive mixer dependig on the level of you signals. Just an attenuator on every input tied together with 1K resistors.
Or you could use the attached schematic for an active mixer. (you can add attenuators on the inputs for level control if you want) |
oh thanks !
passive mixer would be great! I have to try if I have enought signals level...
AMZ mixer seems to be a pretty good solution, it is a pitty I can't use it with 9v battery so I do not need power supply... anyway thank you!! _________________ Yes!
Oh Yeah!
Wow! |
Lorenzo
Posted: Mon Feb 10, 2014 3:32 pm Post subject:
thank you so much! _________________ Yes!
Oh Yeah!
Wow! |
Dave Kendall
Posted: Wed Feb 12, 2014 1:28 pm Post subject:
You might want to check out the TL061 - it uses quite a bit less current than the TL071, at the expense of some slight increase in noise. In practice any extra noise was not noticable in the one I built for a guitarist, and the batteries last a lot longer.
A couple of notes - the Orman circuit uses a 150K resistor in the opamp's feedback loop to give some amplification when the output level is turned up all the way. If you don't need that, then replacing the 150K with a 100K will give unity gain at the output.
The circuit also has an inverted output - this may not be a problem. If it is, then simply use a TL062, and wire the second opamp to the output of the first, before the 10uF cap, with a 100K series resistor into the - input, and a 100K resistor from the output to the - input. Tie the + input of the second opamp to the same point as the + input on the first opamp. This is the classic dual inverting mixer.
Dave _________________ "Everything in moderation, including moderation" |
Lorenzo
Posted: Mon Feb 17, 2014 12:06 pm Post subject:
Dave Kendall wrote: |
Dave |
...noise is good!
thank you! _________________ Yes!
Oh Yeah!
Wow! |
JingleJoe
Posted: Thu Feb 20, 2014 11:55 am Post subject:
I was going to suggest what phobos was saying so I'll add this:
 _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
Lorenzo
Posted: Sat Feb 22, 2014 2:55 am Post subject:
JingleJoe wrote: | I was going to suggest what phobos was saying so I'll add this:
[/img] |
... Rmix1-2-3 could be pots so we have the chance to adjust the input volume. It' ok!
but I think I will try TL071... I think I have a couple at home...
thanks _________________ Yes!
Oh Yeah!
Wow! |
JingleJoe
Posted: Tue Mar 11, 2014 1:21 pm Post subject:
that^ right there is how i do most of my signal mixing, nice depiction phobos you can use different value resistors aswell, to weight the different channels so one input could be louder or quieter  _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Lorenzo
Posted: Tue Mar 25, 2014 6:02 am Post subject:
PHOBoS wrote: | Lorenzo wrote: | ... Rmix1-2-3 could be pots so we have the chance to adjust the input volume. | Actually you would need to add the pots before the resistors |
ooh thanks! _________________ Yes!
Oh Yeah!
Wow! |
col2
Joined: Feb 15, 2014 Posts: 16 Location: Melbourne Australia
