today> Twyndyllyngs not postponed Chez Mosc
PCB designs with partial assembly in mind?
Page 1 of 1 [5 Posts]
droffset
PostPosted: Thu Feb 27, 2014 1:46 pm    Post subject: PCB designs with partial assembly in mind? Reply with quote  Mark this post and the followings unread
I'm starting to get a handle on Eagle and what I'd like to do is:
1. Design using both surface mount parts and through hole.
2. Have a professional service manufacture the pcbs and do all the surface mount stuff for me.
3. Then do the through hole parts myself.
Has anyone else tried this and can you give me some thoughts about your experiences?
Thanks
S
Edit: Spelling mistakes.
gdavis
PostPosted: Thu Feb 27, 2014 9:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't be afraid of doing SMD yourself, it's really not that difficult. Decent soldering iron, flux pen, tweezers and a magnifying lamp and your set.
droffset
PostPosted: Fri Feb 28, 2014 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I hear ya, it's really more about expediting the process and getting a nice result as quickly as possible. Long story, circumstances, life, reasons, etc etc etc.
memetix
PostPosted: Sun May 11, 2014 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
i second the idea of rapid assembly with sm. No flipping back and forth, no putting things in backwards.. well, less so. Smile no parts falling out or burning your finger while you hold it in upside down.
just go with 805 or 1206 and assemble from the inside out and put the big stuff in last, excepting soic's
rutgerv
PostPosted: Fri Oct 09, 2015 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi memetix,
I think it's a good idea, not for prototyping (that can be done by hand, even SMT), but for production it's nice. I decided to try it too for two modules I recently made available. Logistically it's really nice, because it allows you to stick to standard SMT components from a single supplier sent to the factory, while having a wider variety of thru-hole components from various manufacturers and stock these yourself.
Here's the link to the modules I mentioned: https://www.muffwiggler.com/forum/post-2010096.html#2010096
Rutger
ps. For now all info is on Muff, but I'm working on a website.
