Drum Programming with a Klee
Page 1 of 1 [2 Posts]
Ruebezahl
PostPosted: Sat Aug 09, 2014 9:42 pm    Post subject: Drum Programming with a Klee Reply with quote  Mark this post and the followings unread
I just stumbled upon this interesting sequencer, and going through the explanation, i always thought how cool it would be to use it as a Sequencer to drive different drum modules. when you play around with the three outbut busses there should be a lot of surprising rythm changes. So far, on youtube and here in the forum i mainly found that people use it to creaty interesting melodys.
Did someone use the Klee to build interesting drum patterns, and are there sound/videos samples of this?
Audio files: 505
PostPosted: Mon Aug 11, 2014 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
You can try it for yourself!
There is a software version of it here: http://www.defectiverecords.com/klee/index2.html
Demo times out after 20 minutes unfortunately, and there is no saving.
