 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Prophet VS app coming to the iPad
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [10 Posts]
cappy2112
PostPosted: Wed Sep 10, 2014 9:07 pm    Post subject: Prophet VS app coming to the iPad Reply with quote  Mark this post and the followings unread
http://forum.audiob.us/discussion/5702/arturia-iprophet-out-soon/p1
Audio files: 278
PostPosted: Fri Sep 12, 2014 4:35 am    Post subject: Re: Prophet VS app coming to the iPad Reply with quote  Mark this post and the followings unread
fantastic, hopefully I'll be able to port my VS sounds to the app Smile
cappy2112
PostPosted: Fri Sep 12, 2014 5:30 am    Post subject: Re: Prophet VS app coming to the iPad Reply with quote  Mark this post and the followings unread
It would be great if they provided some application to make that happen easily.
Audio files: 278
PostPosted: Fri Sep 12, 2014 9:03 am    Post subject: Re: Prophet VS app coming to the iPad Reply with quote  Mark this post and the followings unread
it would, it appears it will be compatible with the desktop version
it would be nice to be able to import VS sysex somehow
Audio files: 278
PostPosted: Wed Oct 01, 2014 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
it's out and I got it today
I quite like it
The only thing I don't like is that the parameter range for coarse frequency for the oscillators is from 0-127, so it's really hard to set semi-tone intervals
cappy2112
PostPosted: Wed Oct 01, 2014 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I quite like it
Does the original VS have this limitation also?
Audio files: 278
PostPosted: Wed Oct 01, 2014 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I quite like it
no, you can enter course pitch from 0 - 24 semi-tones
DES
PostPosted: Thu Oct 02, 2014 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
How is the midi and audiobus implementation? I'm a bit leary as I believe this is actually coded by Retronyms who also did the iMini...and there were a bunch of issues with it. In fact I don't believe it's been updated to iOS 8 yet...
www.davesneed.com
Audio files: 278
PostPosted: Fri Oct 03, 2014 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Dave, I don't know, as I just play all my apps as standalone things and am still on iOS7 Smile
I do know it is done by Retronyms and is designed to work with Tabletop, which I don't have either Very Happy
Sorry if that's not much help
It sounds good though!
Audio files: 278
PostPosted: Fri Oct 03, 2014 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
From my use of it so far
Main pros, it has extra filter types, extra chorus types, delay, overdrive and it's a lot easier to edit.
Main cons, no dual mode or arpeggiator, no waveform mixing, no random mode, parameter ranges for oscillators are stupid and no velocity/aftertouch
and here's some sounds I made with it for my last AIS radio show
http://electro-music.com/forum/download.php?id=38392
