 Forum index » DIY Hardware and Software » Synthasystem
[BUILD] Synthasystem Quad VCO- Euro format
Post new topic   Reply to topic Moderators: dingebre
synthcube
PostPosted: Mon Oct 20, 2014 12:54 pm    Post subject: [BUILD] Synthasystem Quad VCO- Euro format Reply with quote  Mark this post and the followings unread
Greetings all
This thread is meant to provide resources for anyone embarking on the build of the Steiner Synthasystem Quad VCO using the euro format clarke robinson panel -- notes, questions etc.
With gratitude to, and permission from David Ingebretsen and Nyle Steiner, we have made the PCBs, panels, full kits and assembled modules available.
More on David's re-launch of the Synthasystem is here:
http://user.xmission.com/~dingebre/Synthasystem.html
http://electro-music.com/forum/forum-189.html
Kits, panels, PCBs etc are here:
http://synthcube.com/cart/forums.html?route=product/search&filter_name=synthasystem
The build guide is posted here and is also available from the webstore to download. The current version of the PCB set is 1.6.
The project uses three PCBS (Main, Power, HF Correction) and approximately 220 parts (~160 PCB components, ~60 pots/jacks/hardware pieces etc)
[/img]
SSVCOBuildGuideV1_0Binded.pdf
 Filename:  SSVCOBuildGuideV1_0Binded.pdf
 Filesize:  2.66 MB
 Downloaded:  1609 Time(s)
web store: www.synthcube.com/cart
we've acquired MFOS to help carry on Ray Wilson's work: www.musicfromouterspace.com
