Steam Engine Driver's Cab
glow worm
PostPosted: Mon Apr 06, 2015 1:34 pm    Post subject: Steam Engine Driver's Cab Reply with quote  Mark this post and the followings unread
I took another little heritage rail trip today. On the return journey, the driver was kind enough to let me leave the Zoom in the engine cab.
I'll spare you the full 40+ minute version - this is a short journey between two of the stations, with a tunnel at around 5:15.
It wasn't a huge locomotive - just little 0-6-0 tank engine, but it chuffs away quite nicely. I'll not name the railway, as the recording contains some crew chit-chat; nothing controversial, I'm sure - but I wouldn't want to inadvertently get anyone into any trouble.
Recorded in M/S stereo, with mics set to 90 degrees. Despite setting the level quite low (4/10), there was a little clipping on the extreme peaks (occasional short sounds, like shovel clanks and whistle blasts); so I've normalised it in Audacity, to peak at -0.3db, but with the DC offsets left in.
steam_engine_cab_edit_001.mp3
glow worm - steam engine driver's cab (field recording)
 Filename:  steam_engine_cab_edit_001.mp3
 Filesize:  13.91 MB
 Downloaded:  1109 Time(s)
It may stop, but it never ends.
