lysergist
Posted: Wed Jun 22, 2016 12:33 pm Post subject:
Yusynth, Thomas Henry and other stripboard modules Subject description: Yusynth VCA / ADSR / Steiner, Thomas Henry 555... |
Hi Everyone !
I have made some stripboard adaptions of Yusynth modules (VCA/ADSR/Steiner Filter) and the Thomas Henry 555 VCO. As a big fan of stripboard, (many thanks to Minus for the 808 clone), I thought some of you might be interested.
That's my first stripboard designs so they are not optimized. But they are all tested and work fine. The Thomas Henry 555 is huge, it doesn't worth the effort now PCBs are back in stock. (BOM and Schematics : http://electro-music.com/forum/topic-54623.html)
Check the yusynth page, some components might be adjusted.
http://www.yusynth.net/Modular/index_en.html
I hope some of you will enjoy ! I think I will regularly add new stripboard versions.
Description: |
Filesize: |
281.69 KB |
Viewed: |
5371 Time(s) |
Description: |
Filesize: |
214.42 KB |
Viewed: |
4408 Time(s) |
Description: |
Filesize: |
256.78 KB |
Viewed: |
5489 Time(s) |
Description: |
Noise Generator based on Hexinverter's 808 Toms |
Filesize: |
96.59 KB |
Viewed: |
4037 Time(s) |
Description: |
Filesize: |
785.57 KB |
Viewed: |
188 Time(s) |
bamboombaps
Posted: Mon Jul 04, 2016 6:55 pm Post subject:
nice one mate! |
Ayab
Posted: Tue Dec 06, 2016 6:15 am Post subject:
Great! Many thanks for your work on these am going to start simple with building the noise!
All the best |
lysergist
Posted: Sat Feb 18, 2017 5:55 am Post subject:
Roland System 100 LFO*2 + Yusynth's steiner V1
Description: |
Filesize: |
184.08 KB |
Viewed: |
49078 Time(s) |
Description: |
Filesize: |
59.31 KB |
Viewed: |
49078 Time(s) |
lysergist
MapacheRaper
Posted: Mon Jun 18, 2018 5:14 pm Post subject:
This thread is pure gold. Thanks for sharing. Tempted in all them. |
kamielsd
Posted: Tue Nov 13, 2018 2:07 pm Post subject:
Thanks for posting these, just more or less finished the adsr, after earlier finishing the steiner filer (which still can use some troubleshooting, threads with possible solutions for the minor flaws still experienced have been looked up through tfse ).
One thing I noted after initially experiencing some issues with the adsr though, is that orientation of the n4148 diodes can be best double checked with the original schematics, since the visual representation of their polarity seems to be exactly opposite between the 2 modules, and its hard to say in which one it could be called wrong. |
mosheen
Posted: Sat Dec 29, 2018 8:11 pm Post subject:
For anyone else passing by the Barton's Wave Animator uses TL074(3) and TL072(1). |
maltasynth65
Electro_Head
Joined: Jan 21, 2010 Posts: 13 Location: Greater London
Posted: Sat Apr 18, 2020 2:43 am Post subject:
Simple VCA |
Hi peeps, forgive my ignorance, I've recently taken up building vero projects again. Could somebody explain to me what the 'Gain 2' input if for on the simple VCA? I've tried comparing the schem and cant quite work it out. Thanks  _________________ If you can plug it in and it makes a noise, I want it! |
Sven
Posted: Sat Apr 18, 2020 4:45 am Post subject:
It looks like the connection of the wiper of VR2, P2 in the schematic. |
warpeggio
Joined: Oct 14, 2020 Posts: 9 Location: St. Louis, Missouri, USA
Posted: Fri Oct 16, 2020 6:20 am Post subject:
Ah, that ADSR is just what i was looking for! Thanks much! |
Taube
Posted: Fri Oct 23, 2020 7:37 am Post subject:
This is some great stuff!
One question regarding the Barton Wave Animator: the original schematic uses C taper pots, rather than B taper like here. Is this solved here by connecting lug 2 and 3 together? Ive read something before about mimicking C tapers from B tapers, but dont really know the details.
edit: I've checked the schematics and pins 2 and 3 are connected also in the original design with C taper pots, so I am still wondering how the behaviour will change when using linear pots. |
warpeggio
warpeggio
Posted: Sun Dec 06, 2020 2:52 pm Post subject:
Yusynth ADSR |
Hello again!
I was inspired by the Yusynth ADSR layout that's in this topic to make my own version of it. My main goal was to be able to fit 2 of this circuit on 1x small stripboard, and while it is a little crowded, i'd say the mission was accomplished.
I've restored the BS170 that was in the original schematic, and it does indeed improve the behavior when the gate recycles before the Decay cap can discharge. I've also restored the short circuit protection resistors.
Description: |
Filesize: |
815.73 KB |
Viewed: |
257 Time(s) |
Description: |
Filesize: |
772.94 KB |
Viewed: |
387 Time(s) |
Description: |
Filesize: |
298.17 KB |
Viewed: |
573 Time(s) |
redbuttonplayer
Posted: Mon Oct 18, 2021 4:45 am Post subject:
can I use bc548 instead bc547? Are equivalents? |
