 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Nomad connection issue through USB Midisport 4x4
baggerwerk
PostPosted: Sun Oct 30, 2016 6:03 am    Post subject: Nomad connection issue through USB Midisport 4x4 Reply with quote  Mark this post and the followings unread
Hey guys.
I'm having some trouble connecting my Nord Micro Modular to nomad. Nomad itself is running fine, only I can't connect to the MM and look into the patches. Any help would be greatly appreciated.
This is the error that pops up when I try to connect by clicking the yellow button. I'm running on OSX Yosemite 10.10.5 (14F27)
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1477832334418 [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:715)
at java.awt.EventQueue.access$400(EventQueue.java:82)
at java.awt.EventQueue$2.run(EventQueue.java:676)
at java.awt.EventQueue$2.run(EventQueue.java:674)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:86)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:685)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1477832334418 [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmProtocol.heartbeatImpl(NmProtocol.java:5Cool
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular$SchedulingProtocol.heartbeatImpl(NordModular.java:252)
at net.sf.nmedit.jnmprotocol2.AbstractNmProtocol.heartbeat(AbstractNmProtocol.java:154)
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:114)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:358)
... 17 more
