crackle synthesizer
Page 1 of 1 [4 Posts]
noisefield
PostPosted: Sat Feb 11, 2017 7:50 am    Post subject: crackle synthesizer Reply with quote  Mark this post and the followings unread
hi !
i'm buildind - try to building - a crackle synthesizer like this one
https://www.youtube.com/watch?v=GY-XunukSHQ
https://vimeo.com/1204085
i've already build one crackle box with this vero and know it's time to make the bigger one.
there are some information and picture on this site
http://www.polynominal.com/steim-cracklebox/index.html
i already have the "touch" panel, a buffer/mixer for line out and almost the amplifier (it will be base on a lm 386).
the controls on the crackle synth are :
a FM like (send one crackle on the in of the other) crackle 1 in 3 / 3 in 2 / and 2 in 1 with a on/off switch and an amount for each.
A pitch control (the 1M resistor of the schematic is replace by a pot - may be a 10M but for mine i have a 5M and a 5M resistor that can be connect in serie)
A keyboard control on/off for each crackle.
know i have a lot of trouble with the keyboard design...
i really can't figure out how to make it work.
I assume that it will act on the resistors (the 5M pot and 5M resistor) that act on the pitch of the crackle
is someone have made a thing like this before and can help ?
thanks
 Filesize:  60.08 KB
 Viewed:  373 Time(s)
masterofstuff124
PostPosted: Sat Feb 11, 2017 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
im also interested in building one of these but I cant find the chips anywhere.
noisefield
PostPosted: Sat Feb 11, 2017 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.ebay.fr/itm/401092308207?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
i have bought four here and it's good
nicolas3141
PostPosted: Wed Mar 08, 2017 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I have started from the steim circuit and derived a very similar circuit with no hard to find parts (all discrete) and a couple of small enhancements.
http://electro-music.com/forum/topic-64453.html
I also found that interconnecting a couple of them allowed for some pretty wild noisemaking. I have never gone beyond 2. But I also found they make interesting processors to feed other audio through. I have sent a simple synth through which was fun. And my current favourite setup is to send a contact mike through.
I would definitely recommend an output transformer (1:1 or similar) for isolation.
I would recommend sticking with the touch contact operation and not keyswitches as many good sound variations come from light vs heavy touches that create circuits with varying resistance.
Nicolas
