Posted: Sat Oct 27, 2018 5:11 am Post subject:
g.gabba wrote:
QBERT´s friends are also my friends!
well done,
but if you keep that pace of work there is a danger that u get lost in the space-time, but how we can life wihtout you? please take care.
Posted: Tue Nov 06, 2018 12:35 pm Post subject:
4069 Overdrive
In a local musician facebook group, someone was asking about a good option for a stereo overdrive effect to use with his keyboards and synths. He wanted stereo specifically for a piano patch that he says doesn't sound as good in mono. A lot of people chimed in saying that they would like a good stereo overdrive too, and had just been using dual guitar pedals.
So I built this one and post it for sale in the group. If it sells, then I might do a few more. I built it into a metal watch box. I have three more of the boxes.
It is just a CMOS 4069 wired up like an opamp with variable gain. I also added a 6dB low pass filter for tone control. There is also a volume pot to keep things under control when driving it hard. I also added a bypass switch.
Top
Filesize:
102.24 KB
Viewed:
304 Time(s)
Front
Filesize:
83.15 KB
Viewed:
300 Time(s)
Back
Filesize:
95.26 KB
Viewed:
307 Time(s)
I finished this case , finally!!! It took me so much time ,and now to show off
the case has these modules :
MFOS VCO x 2
111 Buchla Ring Mod x 2
Serge Botom Wavemultiplier x 1
NLC B0ngo x 2
Serge '73 VCF x 1
Hip Bass Drum x 1
CGS CV Processor / Mixer
Serge VCS x 2
Serge Extended ADSR x 1
NLC Difference Rectifier x 1
Grant Richter's Experimental HArdware Neurons
Serge SSG
CGS Slope Detector
Buchla QRV
Osamu Hushuyama Passive Tone control
the inside is messy ,this one is not for photo
Filesize:
1.24 MB
Viewed:
285 Time(s)
Filesize:
1.5 MB
Viewed:
263 Time(s)
Posted: Sun Dec 09, 2018 10:22 am Post subject:
I finished this case , finally!!! It took me so much time ,and now to show off Very Happy
MFOS VCO x 2
NLC B0ngo x 2
Serge '73 VCF x 1
Hip Bass Drum x 1
Serge VCS x 2
Serge SSG
CGS Slope Detector
Buchla QRV
Nice work on the case ! Everything fits well. Nice mix of modules in there as well. Went over to your blog and took a listen to your music. The piece called setting 2, is this from the modular your showing off today? Like the sounds !
Thank you ,yes it's from this synth ,i already got made another case ,panels and distro boards so ,hopefully the whole thing will sound more colorful in future _________________ http://synthacks.blogspot.com/ шематикс
haebbmaster yours looks really neat ,saw it few times somewhere ,nice panels and choice of modules ,cheers _________________ http://synthacks.blogspot.com/ шематикс
Posted: Fri Dec 21, 2018 12:26 pm Post subject:
my second "eurorack" module, renes´s noise source,
not a deadbug, not pad'n'island, its "dead gabba's long island strip style"
ive made the open collector from the transistor available as an input, dunno if it makes sense, time will tell
values adapted to what i had laying around on the workbench from desoldered try'n'fails, only "new" part is a BC637 as noise transistor, which is an original Siemens with ink print, accidently found in the holy Segor-Shop in Berlin back in the days
Filesize:
168.2 KB
Viewed:
235 Time(s)
Joined: Aug 27, 2016 Posts: 40 Location: Windenreute, Germany
Posted: Fri Dec 21, 2018 1:08 pm Post subject:
Cool pcb and cables. Does it run on 220 Volts? _________________ Make modular synthesizers great again!
Modular Synthesizer DIY blog: http://modular.haebbmaster.de
Posted: Sun Dec 23, 2018 1:30 am Post subject:
yeah,
you know in the eastern (dark) part of germany, copper was very short of supply, aluminium was often used instead, so "they" decided to produce chips that run directly off 220V to save the copper for the transformer, they where called TL082SED220 from ROBOTRON.
I received some of them as participant of the "7. electronic youth gathering Teddy Thälmann"
i dont know if the fun-factor-while-building stays as high as it is with simple circuits if you start to build something rather complex like the klee, but never-say-no - and since my own circuits tending to be dumbassly simple, i could get away with this style and maybe i even get better over the time, so its not to hard to look at it anymore
