VCO-1 Power Supply [solved]
Page 1 of 1 [7 Posts]
mr0riiz
PostPosted: Fri Jan 19, 2018 8:14 am    Post subject: VCO-1 Power Supply [solved]
Subject description: How much current do i want the power supply to give the vco-1
I am fairly new in electronics, but very exited.
The VCO-1 needs 15 volts, but how much current should the PSU give.
Would this be standard for a lot of Modular Synthesizers?
mr0riiz
PostPosted: Fri Jan 19, 2018 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
would 150mA do the job?
gabbagabi
PostPosted: Sat Jan 20, 2018 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes 150mA would do the job
not many modules of this kind need more than 25mA
mr0riiz
PostPosted: Sun Jan 21, 2018 6:50 am    Post subject: thank you. Reply with quote  Mark this post and the followings unread
Thank you so much for clarifying Smile
gabbagabi
PostPosted: Sun Jan 21, 2018 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
youre welcome Smile
there are 3 main partys in sdiy
+/-15V
+/-12V
and +9V
if u have meant that by "standard"
so ur VCO need plus AND minus 15V
for the future u should consider something more powerfull, many obscure behaviors are coming from weak powersources
mr0riiz
PostPosted: Sun Jan 21, 2018 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh, i didn't realise that i would need both plus and minus voltage.
How could i go about this, is there any design that can turn my 15v power supply into a +/- 15 v. or would i need two?
gabbagabi
PostPosted: Tue Jan 23, 2018 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
use a second one
connect one ground with one +15V --> this is ur new ground
the remaining +15V is ur new +15V
the remaining ground is ur new -15V
