Mixing note and pitch bend CV
Page 1 of 1 [2 Posts]
Xorophone
PostPosted: Mon Jul 02, 2018 8:10 am    Post subject: Mixing note and pitch bend CV Reply with quote  Mark this post and the followings unread
Hello! I'm going to use the Midi2CV module by MidiSizer for my synth project https://midisizer.com/midi2cv-mk2/ but the 1V/Oct note CV and pitch bend are separated. What's the best way to mix these signals together before feeding them into my VCO?
Thank you!
Edit: Or is it possible to connect the pitch wheel CV to an FM input? I'm building Thomas Henry's VCO-1 (http://www.birthofasynth.com/Thomas_Henry/Pages/VCO-1.html). If that's possible, should I choose exponential or linear FM? Are any modifications to the circuit required to keep the pitch wheel "in tune"?
Xorophone
PostPosted: Tue Jul 03, 2018 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, so I asked the question in the comments on midisizer.com and he said that an attenuated linear FM input would work well with the pitch bend CV. I want to have multiple linear FM inputs. Can I just make a copy of the components related to the FM input (J3, C12, R37 and R42) and then join them at pin 6 on IC2? I guess that should work fine since that's how other mixers work, but I just want to make sure.
http://www.birthofasynth.com/Thomas_Henry/pdf/VCO-1/vco1_schem1.pdf
