Guide to Ambiophonic DSP 5.1 and 7.1 Surround in Windows
Page 1 of 1 [2 Posts]
styjp
PostPosted: Thu Apr 09, 2020 2:10 am    Post subject: Guide to Ambiophonic DSP 5.1 and 7.1 Surround in Windows
Subject description: System wide surround ambiophonic DSP using virtual channel routing
Hello guys. This is my first post here. The reason I am posting is because I had a really tough time figuring out how to apply ambiophonics DSP for watching 5.1 and 7.1 movies through the windows operating system without external modules. It took me about a week to figure it out as there is no guide on how to do this, so now I want to help others.
This will be brief but I will update once I have the time.
Audiomulch
Virtual Audio Cable
VB Audio virtual cable (Part of Voicemeter package)
Virtual Audio Cable:
Open control panel and set virtual cable 1 NC to 1..8 (8channels)
Open Audio Repeater KS
Set wave in to Voicemeter Vaio, set channel configuration to 5.1
Set wave out to virtual cable 1
Edit sample rate in case of cracking
Audiomulch
Set Audiomulch Input found under properties to the Virtual Audio Cable cable 1 we edited above
Set Audiomulch Output to the preferred output
Paste VST plugins (Ambio, crosstalk cancellation, wider, A1 stereo control) in Audiomulch vst folder and refresh plugins
Edit the route
Open VB-Audio Virtual cable control panel for monitoring. Test with your preferred 5.1/7.1 movie player.
This is system wide so all applications with the correct surround output can benefit from the chain we created.
Will be updating with more details and possibly an audiomulch file later.
Audio files: 229
PostPosted: Sun May 03, 2020 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks styjp and welcome to electro-music.com
I think your post will be helpful to others. We look forward to your posts in the future.
