electrolytic capacitor orientation in discrete amplifiers
Page 1 of 1 [7 Posts]
e1999
PostPosted: Sat Mar 13, 2021 4:22 am    Post subject: electrolytic capacitor orientation in discrete amplifiers Reply with quote  Mark this post and the followings unread
Hi there,
If you look at the electrolytic capacitor orientation of the output section of the monotribe
https://usermanual.wiki/Document/monotribesch.191226586/html
-or another example - the mic preamp from Rod Elliott esp found here
https://sound-au.com/project13.htm
-or altec 1592
https://sites.google.com/a/davidmorrin.com/www/home/trouble/transistors/amplifiers/altec-1592a
the capacitor at the input has the cathode towards the incoming signal rather than the other way around as I usually see on other similar circuits.
I was wondering if anyone knows the reason(s) for this?
and also could this be potentially damaging for a device that is connected to it? I'm curious because I have a phone who's audio output jack seems to have been fried and I'm wondering if it might have anything to do with plugging it in to the preamp circuit from ESP.
Thanks very much.
PostPosted: Sat Mar 13, 2021 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I’d say that the monotribe example is backwards while the other two seems ok to me.
To determine how the orientation of the capacitors should be you have to figure out where the most positive voltage usually is and place them accordingly, where the + of the capacitors points towards the most positive voltage.
my synth
PostPosted: Sat Mar 13, 2021 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
As for the esp is concerned, I once was at a talk from an Analog Design engineer and he stated that the best thing that could happen with an opamp when exposed to an esp is to break down immediately because especially opamps that are not esp safe will brake down eventually and usually at the most unconvinient moment...
my synth
Audio files: 297
PostPosted: Sat Mar 13, 2021 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you mean ESD .. I think that ESP in the OP was referring to this pre-amp :
Anyway, it seems highly unlikely to me that connecting that pre-amp to a headphones output would blow up that output.
PostPosted: Sat Mar 13, 2021 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sorry your right (of course Wink )
my synth
Audio files: 297
PostPosted: Sat Mar 13, 2021 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I did like Extra Sensory Perception tho Laughing
(except when that would destroy electronics)
e1999
PostPosted: Sun Mar 14, 2021 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
ok cool thanks for the responses:)
