today> Twyndyllyngs not postponed Chez Mosc
Help troubleshooting Triple Chorus
foogy
PostPosted: Sun Sep 24, 2023 4:01 pm    Post subject: Help troubleshooting Triple Chorus
Subject description: Help troubleshooting Triple Chorus
I have completed the assembly of my Triple Chorus... without much surprise I didn't get it right on the first try Smile
The symptoms are as following:
    Mix output: something that sound close to the input sound. Basically, I'm not hearing any kind of modulation.
    Output 1: weak output
    Output 2: very weak output
    Output 3: strong ouput
    Waveform knobs: does absolutely nothing.
What I have tried so far:
    swapping around the TDA and 4011 IC without noticeable difference in the result outputs.
Some questions:
Is the mixed output supposed to have the effect full on regardless of the Mode Switch position?
Any advice on how to troubleshoot this, things to look for or hints appreciated.
