TR808 Emulation
rrooyyccee
G2 patch files: 10
PostPosted: Fri Oct 04, 2024 11:31 pm    Post subject: TR808 Emulation Reply with quote  Mark this post and the followings unread
Hello,
I've attached a Tr808 emulation in 3 parts. The kit is mostly complete, but does require slots A, B, and C. I've mapped it so that it can be sequenced and performed by an Arturia Impact from C2- B3. C#2 is accent. The voices are based partly on the G2 TR8088 patch in the archives. Some of the voices were modified through to save CPU resources. For example, there is only one conga voice that plays three different pitches each time G2 is struck. The hihat and cymbal is based on a multi-oscillator array, diode clipping, and multiple filters. The snare sounds good is based heavily on the G2 patch that I admired and wanted to have available for my own G1.
To play the 3 patch performance, you will need to load the three patches and set the midi channel of each to 1. I hope this is useful to somebody. If you have any improvements, please do upload your modifications! i think it sounds pretty good: good enough to temporarily retire my $$ eurorack modular drum bento box.
808A KickSnareRi.pch
 Filename:  808A KickSnareRi.pch
 Filesize:  3.29 KB
 Downloaded:  159 Time(s)
808b ClTmCgRim.pch
 Filename:  808b ClTmCgRim.pch
 Filesize:  3.98 KB
 Downloaded:  131 Time(s)
808C Hihat and Cymbal.pch
 Filename:  808C Hihat and Cymbal.pch
 Filesize:  3.61 KB
 Downloaded:  121 Time(s)
