today> Twyndyllyngs Chez Mosc
Program Change-from Micromodular
Page 1 of 1 [2 Posts]
Aelia1725
PostPosted: Thu Apr 10, 2025 2:24 pm    Post subject: Program Change-from Micromodular
Subject description: How to set up MM to transmit program change
Hello
Please can someone tell me how (if it is possible) to set up the MM in the editor to transmit Program Change information?
According to the manual it is possible, but I can't see how. Confused
I'd like to be able to set up one of the buttons (with shift) to send Program Change.
Any ideas? Thanks
Audio files: 321
PostPosted: Thu Apr 10, 2025 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm .. i am not certain .. it has been a good while i've used the nord modulars . but let me try ... and I maybe wrong ...
The NM G2 has midi send modules, and one of those can send program changes. The NM Classic (G1) has no such modules.
Both the G2 and the Classic will send prgram change info if you change the program on the synth .. and IIRC .. this can be enabled or disabled in the settings.
So .. I think that the answer to the "question"
"I'd like to be able to set up one of the buttons (with shift) to send Program Change. "
would be - no that is not possible for the NM Classics. Crying or Very sad
