Penfold P2V: First success
Page 1 of 1 [5 Posts]
stefano
PostPosted: Wed Feb 21, 2007 1:59 am    Post subject: Penfold P2V: First success
Subject description: .. but a lot of work is still needed..
Razz Laughing Very Happy Smile Exclamation Razz Laughing Very Happy Smile Exclamation Razz Laughing Very Happy Smile Exclamation Razz Laughing Very Happy Smile Exclamation Razz Laughing Very Happy Smile Exclamation Razz Laughing Very Happy Smile Exclamation Razz Laughing Very Happy Smile Exclamation Razz Laughing Very Happy Smile Exclamation SOMEHOW, IT STARTED TO WORK !!!!! Razz Laughing Very Happy Smile Exclamation
PRODUCTION OF SAMPLES AND PHOTOS IN PROGRESS.... Cool
Yes, sir, yesterday the Penfold F2V Guitar to Synth Interface started to convert guitar frequencies to voltage. I say "SOMEHOW" because I had to make a little mod (or bypass) to start it work. And I think that the device is not working in the way that Penfold designed it... but it WORKS.
I suspected that the signal path "stopped" at the gates of the quad switch 4016BE (I use a MC14016BCP for IC4). IC4 is driven at pin 13 (control pin) by a signal coming from pin 4 of IC11b, so I wondered what would have happened if pin 1 and pin 2 of IC4 would have always connected (like if the control al pin 13 was always enabled). The easiest way to do this is to **short** pin 1 and pin 2 of IC4. I did it and immediately the circuit started to convert frequencies to voltages.
The mini sound lab accepted the 1V/Octave scale produced by Penfold P2V.
I played an A (5th guitar string), tuned the osc-1 Minisoundlab and VR2 (shift control). Then I played the same string at the 12th fret (1octave up) and I used the VR3 (gain control) to tune the sound from the oscillator.
I didn't win the war, but I think at least a good battle! I'm on my way to completely debug this circuit because I don't actually like this bypass Twisted Evil .
Next step I'd like to do with an oscilloscope (any advice accepted Very Happy ):
- controlling the signal at (IC11 pin 4) = (IC4 pin 13) (after generation of quad switch control signal)
- controlling the signal at IC10 pin 6 (before generation of quad switch control signal)
Stay tuned
Fernando
PostPosted: Wed Feb 21, 2007 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
a very interesting quest!
hope to read and listen more soon!
synthmonger
PostPosted: Fri Feb 23, 2007 10:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
<---interested in seeing how this works Cool
Chrometuna
PostPosted: Fri Oct 05, 2007 12:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Any more progress with this?
stefano
PostPosted: Tue Oct 09, 2007 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah look at the main topic "A NO-MIDI..." .
http://electro-music.com/forum/topic-14921.html
It started to convert P2V even if with limitation (works better if you play guitar around the 6th ot 12th fret)
