Is the G2 expansion board worth buying?
Page 1 of 1 [11 Posts]
dioioib
PostPosted: Mon Jun 16, 2008 6:10 am    Post subject: Is the G2 expansion board worth buying? Reply with quote  Mark this post and the followings unread
Is the G2 expansion board worth buying. I'm not overly concerned with polyphony but I am interested in making more complex patches. I can not find much detail on the additional features this board will give me. Can anyone make a suggestion.
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
Audio files: 309
PostPosted: Mon Jun 16, 2008 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
These give some views on the topic :
http://electro-music.com/forum/viewtopic.php?highlight=expansion&t=25622
http://electro-music.com/forum/viewtopic.php?highlight=expansion&t=16568
http://electro-music.com/forum/viewtopic.php?highlight=expansion&t=11310
http://electro-music.com/forum/viewtopic.php?highlight=expansion&t=11216
http://electro-music.com/forum/viewtopic.php?highlight=expansion&t=4098
http://electro-music.com/forum/viewtopic.php?highlight=expansion&t=4512
Audio files: 309
PostPosted: Mon Jun 16, 2008 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
And personally I think the expansion to be useful for making larger patches, this due to the possibility to exchange information between patch parts through audio buses and the internal MIDI communications. Anyway, that's the way how I use the expansion mostly.
dioioib
PostPosted: Mon Jun 16, 2008 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow thanks for the links.
I'm seriously considering buying it.
Would you suggest getting it professionally installed or is it something I can do myself? I read the tech docs on install and it looks easy but I dont want to void the warranty.
Audio files: 309
PostPosted: Mon Jun 16, 2008 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I was searching for the above links I also found a couple about the installation & wondered if I should include those Very Happy I used the forum search function for that with the phrase "g2 AND expansion" selectivly on the Nord modular forum - in case you would want to search yourself.
It boils down to : it's not hard to do it yourself.
When you encounter problems you can post a question here & will likely get a response to it. Most people here having an expansion installed it themselves. Even when I order my engines with expansion I got the expansions delivered separately.
BobTheDog
Audio files: 32
PostPosted: Tue Jun 17, 2008 12:18 am    Post subject: Reply with quote  Mark this post and the followings unread
It is very easy to fit in the keyboard as well.
Andy
dioioib
PostPosted: Tue Jun 17, 2008 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been reading that some people are missing the spacers for the expansion board. Is there a suitable replacement? Are they metric hex spacers, plastic, etc?
Flevo
PostPosted: Tue Jun 17, 2008 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just discovered that with an expansion board you can also use the vocoder!!
Fozzie
G2 patch files: 49
PostPosted: Tue Jun 17, 2008 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, yes, you can. But you can use the vocoder module as well without the expansion. It doesn't matter which modules you use with the expansion, you just get a net doubling of processing power.
Spinning at ~0.0000115740740741 Hz
Audio files: 233
PostPosted: Tue Jun 17, 2008 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
To me, the expansion board is essential. Get it. Wink
ark
G2 patch files: 31
PostPosted: Mon Jun 30, 2008 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you have not already purchased a G2, I suppose it's worth mentioning that novamusik.com is selling a G2 plus an expansion board and gig bag for the same price that most people are charging for a G2 alone.
