Yusynth Sample and Hold + Random Module
Page 1 of 1 [5 Posts]
Aottens
PostPosted: Wed Jun 09, 2010 11:39 am    Post subject: Yusynth Sample and Hold + Random Module
Subject description: A question
Hello Yves, and others,
I was planning on building this module for my modular soon, but at first I've got 1 question. The site says:
Separate supply rails are used for the two sub-modules.
I don't get this part exactly, do I need a new power supply for it? Or what?
The combined PCB only has 1 connector, so I suppose there is only 1 cable, actually 3 ofcourse, going to the module.
Any tips on this would be nice, cause I'm a littel confused.
Sebo
PostPosted: Wed Jun 09, 2010 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
You need only one power connection.
The mention of separate supply rails refers to the fact that there are
independent circuits, so no noise crosstalk will happen.
Sebo
My Music:
Aottens
PostPosted: Wed Jun 09, 2010 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
So if I'll make the combined version everything works fine with just a single connector coming from my main power supply?
Sebo
PostPosted: Wed Jun 09, 2010 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeap.
Sebo
My Music:
yusynth
PostPosted: Sat Jun 12, 2010 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes Sebo said it all.
I was referring to the fact that I had to design a PCB with separated power tracks for the sub-modules in order to avoid crosstalk between the modules.
You just have to build it as shown Wink
Yves
