 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Revised random chord/melody
Page 1 of 1 [2 Posts]
G2 patch files: 626
PostPosted: Tue Dec 07, 2010 1:40 pm    Post subject: Revised random chord/melody Reply with quote  Mark this post and the followings unread
Melody/chord generator in slotA(yellow). It produces 'runs' of 8 notes in up or down direction.
Consecutive notes are spaced 1 or 2 semitones apart. The delay shift registers are used to store the 8 note and velocity values. Only 4 of the values are used as notes.
Notes in the run are played (sometimes) as they come, and as chords from the memory.
The chord gates go through modulated logic delays in series to give (randomly) strum or mini arpeggio effects.
The bass in slot D has its note value set to the lower of either the top or bottom chord note (because the runs go up or down). The selected bass value is then sent through a MOD 12 to limit it to one octave.
The pad notes are the same as the pianoish chords but via a mod 36.
ChordGen04.prf2
Random chord generator.
 Filename:  ChordGen04.prf2
 Filesize:  14.53 KB
 Downloaded:  2366 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Fri Dec 10, 2010 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome patch and the other new perfs are great too. Smile Haven't got round to studying them yet though. Embarassed
iP (Ross)
