today> Twyndyllyngs Chez Mosc
Scott Stites/Buchla 291 adaptation
Page 7 of 8 [199 Posts]
Luka
PostPosted: Mon Dec 21, 2009 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeh there isnt anything too big to fix, if you want to etch them now let me know via pm and ill send through the files
problemchild
melbourne australia
Luka
PostPosted: Sat Dec 26, 2009 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
here you go
i left the processor on there, it can be turned into a normal mixer pretty easy
the pdf shows the blocks so you can work out which bits not to populate if you dont want to use it
i beefed up the ground and rail traces too Smile
<removed>
problemchild
melbourne australia
LetterBeacon
PostPosted: Sun Dec 27, 2009 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant, thanks for the Christmas present!
TekniK
PostPosted: Wed Nov 03, 2010 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
somebody knows where i can find the original schematic of this one (not any re-draw)?
beautyofdecay_
PostPosted: Wed Nov 03, 2010 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the original schematic: http://rubidium.dyndns.org/~magnus/synths/companies/buchla/Buchla_2910_150.jpg
And pics of the the PCB and front panel back...
Buchla 291 PCB component side
 Filesize:  72.32 KB
 Viewed:  597 Time(s)
Buchla 291 PCB traces
 Filesize:  73.25 KB
 Viewed:  563 Time(s)
Buchla 291 front panel back
 Filesize:  58.11 KB
 Viewed:  598 Time(s)
TekniK
PostPosted: Wed Nov 03, 2010 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Beauty!
Peake
PostPosted: Tue Feb 22, 2011 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using both VTL5C3 and VTL5C1, my 291 adaptations (second to last Luka/Funkyfarm) do not close completely (any of the three filter modes passes up to around 100Hz, on a guess, probably higher). With res up, the BPF goes up to and past audibility, with some range left on the Fc pot, so I'm looking for a way to drop the overall Fc a bit. Edit: 910pf instead of .001uF fixed the Fc problem.
Loving this, thank you to everyone. Would love to get a logic solution to have gate pulses switch between response modes to a single output.
Also note that it sounds and responds just the same with the 5C1, which are going for $2.00 each at allelectronics.com, part number VTL5C1. Same response times as the 5C3.
Edit: 5C1 are sold out.
Luka
PostPosted: Tue Feb 22, 2011 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
ill check mine when i get a chance but im pretty sure both my 291s will cut off completely in all modes
problemchild
melbourne australia
Luka
PostPosted: Wed Feb 23, 2011 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
no wait im making stuff up
you are correct mike
problemchild
melbourne australia
questionable
PostPosted: Wed Feb 23, 2011 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm going to add this to my project list (and probably bump it to the top).
Luka: Is your rev3 pdf above the final version, with everything working correctly?
Great layout!
Sounds Questionable
Peake
PostPosted: Wed Feb 23, 2011 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't want to be correct! Think, what to do? Cool
Edit: I don't remember if the 291-style BPF on my old Buchla 212 closed more than this build; I do remember it whoomping into the bass due to the non-linear response curve. Thanks Luka!
arnoid
PostPosted: Thu Feb 24, 2011 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I also gonna build this one, after building the 292 I really like the "vactrol" sound Smile
How ? Can you explain this a bit plz ?
http://www.soundcloud.com/arnoid
http://www.facebook.com/arnoid
Scott Stites
Audio files: 96
PostPosted: Thu Feb 24, 2011 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've wondered about that for years....thanks for mentioning it!
My Site
arnoid
PostPosted: Fri Feb 25, 2011 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Ignore this dumb question it's already in your layout Smile
kupfer_m
PostPosted: Wed Mar 23, 2011 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
One question regarding Luka's layout:
Are the components in the parts view viewed from the copper side instead of the usual top view most of us use... or do I miss something?
Luka
PostPosted: Wed Mar 23, 2011 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
the orientation is reverse from normal - this is from mark verbos' layout
you can orientate yourself from the IC layout
problemchild
melbourne australia
Peake
PostPosted: Mon Mar 28, 2011 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is definitely an issue here- I note that the Buchla 291 front panel lists a frequency range from 30Hz up. My builds are not closing to 30Hz.
Edit: Got some 910pf caps as spec'd in the original and replaced the .001 I had been using. Also swapped power in resistors to the 1R as indicated on the original Verbos design. Now closes nicely.
arnoid
PostPosted: Sun May 08, 2011 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished a dual 291 vcf Smile Very nice/versatile sounding filters...
A note for other builders I used the V3 layout of luka and there's a litlle kludge: pin 2 and 3 of the tl082 are mixed up so you have to cut the traces to these pins and solder wire's to have a working mixer section.
mph
PostPosted: Tue May 10, 2011 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to build this filter since I've seen this topic, but some things are not clear for me (still too noob ).
You're right about the pin 2 and 3 of the 082 in the mix section... here a small redesign could be great: using the three 200K resistors as jumper above the -V track to allow the 100nF cap to be connected to ground isn't it?
but what is the purpose of the two 100K resistors near the psu connector?
Luka
PostPosted: Wed May 11, 2011 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
they are part of the processor circuit. i added them there to avoid having them flying between CV input and processor potentiometers
see here:
sorry about the mistake
ill try fix it up asap
problemchild
melbourne australia
mph
PostPosted: Wed May 11, 2011 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Luka
do you have a full schematic with this mod included? I've checked again thru the 7 pages of this topic and I've only seen the redrawn version from Scott Stites which does not show the CV processor.
That would be very helpful for me to figure out the whole wiring.
And just to be sure, R47 should be a trimmer even if it appears as a fixed resistor on Scott's version isn't it?
arnoid
PostPosted: Thu May 12, 2011 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
You can use the wiring from the schematic luka posted it's the same.
mph wrote:
Thanks Luka
yep
mph
PostPosted: Sat May 14, 2011 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks arnoid,
concerning the wiring, I was just thinking there could be some interconnections between the voltage processor and the rest of the circuit... but it appears it's not the case indeed. Sorry for that stupid request Cool
brother303
PostPosted: Tue May 17, 2011 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Arnoid,
Which 082 exactly? The lower one (next to the lp/bp/hp-outs) on the left side on Lucas´ v3-pcb?
Thanks and kind regards
Greg
Best regards
Greg
Peake
PostPosted: Wed May 18, 2011 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the above pic of the original PCB, I note a pair of silver mica caps in each filter. Wonder if those are the .022s?
