steffensen
Posted: Thu Mar 21, 2013 10:45 am Post subject:
| AndyR1960 wrote: | Oh dear, not this old thread again
Last week, I finally got off my a$$ and did some work before zooming off for a few weeks.
I'm glad to report that this VCO works fine with +/-12v with no modifications. No problems at all with 1v/Oct scaling or tuning. Unfortunately my scope is down at the moment, so I can't properly check the waveforms, but they sound fine to me, just a slight adjustment on the pulse width to bring it to 50% - I'll check when I'm back home.
I've been meaning to test this for ages - got a new PSU, so I was able to try it before re-calibrating to +/-15.
Hope this helps. |
I can only agree with Andy here. Working just perfect.
Actually, i planned to find the PW value and replace my crappy trannys next week or so. Working on thinning out the backlog atm..
If you figure it out before i get to it, thats allright by me.  |
LetterBeacon
Posted: Mon Apr 29, 2013 3:22 pm Post subject:
I've had my dual oscillator board running for a few years now. The other day I noticed that the mild steel bracket I used was getting a bit rusty, so I replaced it with a aluminium one. Fine. Everything appeared to work ok after I'd replaced it.
However, I didn't check the 1V/Oct at the time. I've just tried using it and now I can't get it to change pitch by applying a CV to the 1V/Oct jack at all. Neither oscillator will change pitch.
Now logic tells me, it MUST be where I've broken a connection or something when I changed the bracket over, but I can't see anything wrong at all.
If both oscillators aren't responding to the 1V/Oct jack, whereabouts do you think I should start looking on the board?
Thanks for your help! |
steffensen
Posted: Tue Apr 30, 2013 2:02 am Post subject:
| LetterBeacon wrote: | I've had my dual oscillator board running for a few years now. The other day I noticed that the mild steel bracket I used was getting a bit rusty, so I replaced it with a aluminium one. Fine. Everything appeared to work ok after I'd replaced it.
And you have checked the solder joints from where the CV is coming in to the board with the Continuity test i guess? Should be easy to find if doing this i would guess.
Btw, i asked this in the "ghost-thread" about this build but thought id ask here as well now - How did you guys solve the VCO's locking in to each other?
I get as much as they shouldnt share the same Ground trace, but when using a aluminium panel, its hard to avoid. |
LetterBeacon
Posted: Sun May 12, 2013 1:14 pm Post subject:
| steffensen wrote: | | And you have checked the solder joints from where the CV is coming in to the board with the Continuity test i guess? Should be easy to find if doing this i would guess. |
It turns out I managed to ground the CV input -all fixed now.
However, I have just noticed another problem. I thought something sounded a bit strange with the audio out, so I took a look on the oscilloscope.
As you can see, the bottom of the square wave is wonky. When I first built this module years ago, this was straight. This occurs on both oscillators. Where should I start looking to rectify the problem? |
isak
LetterBeacon
Posted: Sun May 12, 2013 1:44 pm Post subject:
| It's in AC mode, and I don't know the rate. It's the same shape no matter the rate, I think. |
steffensen
Posted: Sun May 12, 2013 2:03 pm Post subject:
I had the same scope results when i was troubleshooting mine before.. dont really remember how i got this result, but it was when altering the resistor values. Gonna think about it, see if i can remember.. might be in the schmitt trigger area.. Seems the most obvious right now.
How does the Saw look like? Can you scope the output from pin 3 of the 3086? (or the closest leg of any component on the trace from it) |
isak
Posted: Sun May 12, 2013 2:47 pm Post subject:
try to put it on dc mode and lower the pitch, see if you get the same results. _________________ http://www.myspace.com/mgmtrance |
Posted: Sun May 12, 2013 6:58 pm Post subject:
Yah, what Isak said. I have an AC/DC switch on my VCF inputs and I was looking at them with the scope the other day, and a wonderful square wave input was immediately warped to have slopes top and bottom in AC mode. And there were definitely audible effects of same, even with the filter wide open.
I would hope a scope's AC input would be less prone to such things, but.... |
LetterBeacon
Posted: Mon May 13, 2013 6:00 am Post subject:
Thanks for the replies!
So in AC mode, the higher the frequency, the less wonky the bottom of the square wave. So lower frequencies have more of a wonk.
In DC mode the square wave is normal, as I expect a square wave to look. However the wave jumps down to bottom of the display meaning I have to use the DC offset knob to bring it back to the centre.
Does this mean there's a significant DC offset on my sound waves? |
steffensen
Posted: Mon May 13, 2013 6:03 am Post subject:
These VCO's have a DC offset, thats right. Not sure if anyone in here did try to buffer them? Curious on the result. |
LetterBeacon
Posted: Mon May 13, 2013 12:03 pm Post subject:
I thought the DC offset was just on the ring mod out?
Hmmm, so it's all ok then? The problem was my oscilloscope? |
Broadwave
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Wed May 15, 2013 11:21 am Post subject:
I know it's not much help, but I'm not getting any problems, the square waves are flat top & bottom in AC or DC on my scope (which is way past it's best!!). Also got a clean saw wave.
I've rechecked all my boards, and there's nothing that I've added or changed... the files I uploaded are exactly as I use here at home.
All the components I use are exact (no substitutions) and I use Hydro Flux Solder (water soluble - leaves no flux on the board once cleaned with a toothbrush and water!)
I wish I could be of more help... I feel a bit useless not being able to.
165.42 KB |
| Viewed: |
600 Time(s) |
161.96 KB |
| Viewed: |
568 Time(s) |
144.38 KB |
| Viewed: |
612 Time(s) |
isak
Posted: Thu May 16, 2013 4:13 am Post subject:
Hi Andy.
Thank you for your amazing work!
Btw is there any chance you will do the vca section some where in the near future?
Cheers man and thanks again!!! _________________ http://www.myspace.com/mgmtrance |
LetterBeacon
Posted: Thu May 16, 2013 9:35 am Post subject:
Hi Andy,
I built the VCOs nearly five years ago now, and at the time they worked perfectly. I put my modular in storage for a couple of years and have now got it out again.
I noticed a bit of corrosion on the PCB, and used some isopropyl alcohol to scrape it off. Measuring the DC offset and the wonky square waves must mean that something is still wrong, as I'm sure I used to have normal waveforms and no DC offset before.
So you posting those wave shapes means that I'm not going mad, and it is possible that I had perfect wave shapes a few years ago.
It's strange that I get the weird wave shape on both oscillators. Do the square waves share some circuitry? I think they share the ring mod section, don't they? Maybe I need to look there. Actually, the ring mod has a DC offset doesn't it? Maybe something's gone wrong around there, and the DC offset is added from there.
What do you think? |
Broadwave
Audio files: 6
Posted: Thu May 16, 2013 9:54 am Post subject:
@LetterBeacon
The only component I can think of that's shared is the 4011, maybe start there... check the square waves before they go to the 4011 too?
Are your Saw waves OK? |
LetterBeacon
Posted: Thu May 16, 2013 9:57 am Post subject:
Yes the saw waves are fine, although I think they have the DC offset on them.
Unfortunately I won't have a chance to check anything until early next week, but I'll keep you posted.
Just to confirm, is this the correct schematic for this version of VCO: http://www.arpodyssey.com/schematics/ody_36.gif |
steffensen
Posted: Thu May 16, 2013 10:12 am Post subject:
| steffensen wrote: |
| AndyR1960 wrote: | @LetterBeacon
| LetterBeacon wrote: | Yes the saw waves are fine, although I think they have the DC offset on them.
If the Saw is ok, then the core of the VCO's are ok. Which is good to know, and makes it easier to track down. |
Broadwave
Audio files: 6
Posted: Thu May 16, 2013 10:30 am Post subject:
You're in the right area... but wrong page, that's the link to the VCF/ADSR etc
You need the schematics for board BII, the MKII/III Oddy VCOs |
LetterBeacon
Posted: Mon May 27, 2013 10:59 am Post subject:
I just checked my saw waves (pin 3 on the 3046) and in AC mode there's a tiny little curve to the triangle slope, so it looks like my saw waves aren't healthy!
I get a 'rounded' square wave measuring just over 2V with a 2V offset going into the 4011 on (pins 2 and 12).
I then get a 15V square wave -normal looking in DC mode, wonky looking in AC mode- at pins 3 and 11 of the 4011.
I've attached photos in case they help at all...!
| This is the saw with a slightly bend on it, measured from pin 3 of the 3046. |
2.72 MB |
| Viewed: |
852 Time(s) |
| This is the square wave going into the 4011. |
2.77 MB |
| Viewed: |
869 Time(s) |
LetterBeacon
Posted: Wed May 29, 2013 8:02 am Post subject:
| Because this is an issue with both oscillators, could this be a test equipment problem? Could the AC input on my scope be warping the waveforms? |
Posted: Wed May 29, 2013 8:17 am Post subject:
| Yes, actually I've seen that with my scope, which admittedly is probably a lower-end device. |
LetterBeacon
Posted: Wed May 29, 2013 8:36 am Post subject:
Hmmm, that's interesting.
My one is a secondhand one I found on a classifieds ad, so I don't think it's particulary high end.
It looks to be the model below Andy's, although he's posted perfect wave shapes. |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Wed May 29, 2013 12:52 pm Post subject:
| The probes you use with the scope are also of influence, do the ones you use have a trimmer cap inside (adjustment screw)? |
LetterBeacon
Posted: Wed May 29, 2013 4:11 pm Post subject:
| Interesting. They don't have a trimmer, but they have an attenuation switch. |
