 Forum index » Instruments and Equipment » MAX/MSP - Pd
Simple Newbie Question
Page 1 of 1 [7 Posts]
Monkeyfinger
PostPosted: Tue Jun 21, 2005 6:39 am    Post subject: Simple Newbie Question Reply with quote  Mark this post and the followings unread
Are Max patches and PD patches interchangeable?
What are differences?
TIA!
Ben
diskonext
PostPosted: Thu Jun 23, 2005 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, but then again, no.
Both programs have different objects, they have many similar objects, many same objects. Basic flow is the same, basic ideas are the same.
The ASCII-file format describing the patches might even be trivial to exchange / convert. But don't count on any real interoperability / compatibilty...
-diskonext
:wq
Monkeyfinger
PostPosted: Thu Jun 23, 2005 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
How very zen. Smile
Maybe a better question is:
Are there specific strengths of each program that that would make somebody choose one over the other?
Can you give any examples?
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Jun 23, 2005 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
MAX/MSP supports the Rewire protocol. that's a big plus for me.
PD is freeware though Exclamation
PostPosted: Thu Jun 23, 2005 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Pd has a VST version out there. That's just about as good as rewire, depending on what tools you use.
Audio files: 233
PostPosted: Thu Jun 23, 2005 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't use either program myself, but I'm considering it, if only to learn more. So, it sounds like if you don't know which to use and you are just starting off, it would make sense to start with PD and switch to MAX/MSP when you're sure that it is worth the money. The time you invest with PD will not be wasted if you switch later to MAX/MSP. Is that a good summation?
Monkeyfinger
PostPosted: Thu Jun 23, 2005 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use Reason & Reaktor.
I agree with Howard that PD only has time investment not money & time.
Sounds like I should be able to link Reaktor with PD via a VST version (as well as other VSTs)
This is the kind of info I'm looking for Very Happy
Thanks everybody!
