Posted: Mon Nov 18, 2019 11:39 am Post subject:
Are you sharp or flat?
If you're sharp, your HF trim is probably providing too much trim, and you need to turn it down and start over.
I don't know off the top of my head which way (cw vs ccw) is "turn it down", unfortunately.
The idea of the HF trim is that, as a VCO gets higher frequency, it tends to go flat, and the HF trim gives a little bit more juice back to the control to bring it up to being in tune. |
cslammy
Posted: Mon Nov 18, 2019 2:53 pm Post subject:
elmegil wrote: | Are you sharp or flat?
Going flat.
Hi Freq trim does almost nothing--I can turn it so it clicks either way, which in my mind means it has gone as many turns as it can go--with very little impact. Maybe a few cents sharp or flat for a 7K triangle, that's it.
Q: For other users, does the HF trim "do a lot"? For the 13700 TH VCOs I built the HF trim was far more effective--but having never put my hands on the maxiums design, I am not sure what to expect here. If the HF trim is impactful on other VCO's I might have another issue somewhere. _________________ Visit my AUDIODIWHY blog and website |
cslammy
Posted: Sat Nov 23, 2019 10:12 am Post subject:
I replaced the trimmers (12 turn cheapos) with bourns 25 turn for normal and HF trim. Seems to have fixed it. I think I just wasn't able to dial in my settings with enough specificity. _________________ Visit my AUDIODIWHY blog and website |
ixtern
Posted: Thu Nov 28, 2019 12:16 am Post subject:
cslammy wrote: |
Q: For other users, does the HF trim "do a lot"? For the 13700 TH VCOs I built the HF trim was far more effective--but having never put my hands on the maxiums design, I am not sure what to expect here. If the HF trim is impactful on other VCO's I might have another issue somewhere. |
Don't know if you still have a problem with HF tracking but yesterday I was tuning my VCO Maximus again and HF trims works as intended. I can see tracking change from about 1000 Hz and up. It's not a big change - a few Hz for a few trim turns but still noticeable. |
matimatil
Posted: Fri May 22, 2020 2:10 pm Post subject:
does anybody by any chance have a sigle sided pcb layout for this?
if not i am probably gona give it a shot, but i am not very good. |
