Wren latest version - 2023.2.8.0
Page 9 of 9 [215 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9
Audio files: 274
PostPosted: Fri Mar 25, 2022 10:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Version 2022.3.25.0 - and you can:
This release uses an installer - stiil - you must not install Wren in a µsoft owned folder (like program flies, desktop, whathaveyou). The installer may survive that though, but Wren still needs user writable files in the exe folder. The installer should warn about it Cool
Audio files: 274
PostPosted: Tue Mar 29, 2022 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
For version 2022.3.28.0 I've updated the installer so it can re-install itself. Also source code can now be downloaded from Wren itself.
Reduced the Wren web page to almost nothing, and started a new, nore responsive wiki, that holds the information from the old web page.
links:
https://bluehell.nl/wren/
https://bluehell.nl/wren/modules.html
https://bluehell.nl/blogje/
https://bluehell.nl/wren/wiki/
wikter
PostPosted: Sat May 21, 2022 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
HI, while trying to install last version my installation folder changed from C:\Audio\Wren to C:\bin\Wren
I reinstalled again to find the exe file because after the first install Wren didn't copied in the expected folder.
I think it may be corrected.
Audio files: 274
PostPosted: Sun May 22, 2022 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi wikter,
Ah, so it goes a bit messy then ... saw you were in the chat too this morning .. I was still sleeping of course Rolling Eyes
Was it the first time you used the installer?
The current installer should - when you do an upgrade from within Wren itself (help menu) - install over the current Wren.
Howver, when the installer is used stand-alone (which unfortunately has to be done the first time the installer is used), it will not know where Wren is and you will have to tell it during the installation.
You can always solve the issue by copying all Wren files except Wren.ini to where you want it to be.
I'll run some tests here too ... later today ... maybe the installer could issue a warning or something when it can not find Wren, or show a dialog to help find the current Wren.
wikter
PostPosted: Sun May 22, 2022 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, it was the first time installed in this machine and I specified c:\audio\wren (and also created a folder to avoid folder owner problems).
I installed it again because I was unaware of where my files went to and again the program changed the path after the second step of the installation.
I did a third "try" after moving & running Wren from the c:\audio\wren
The installer did that c:\bin\wren swap again.
Audio files: 274
PostPosted: Sun May 22, 2022 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah ok, thanks, I see what you mean now - it will indeed mess up the path and it has to be set again after selecting what must be installed.
And this is not what is intended - I will look at it.
Audio files: 274
PostPosted: Sun May 22, 2022 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I've updated the installer (to version 2022.5.22.0) and remade the depending installs (for the full installation and the pre-release) to contain the new installer version as well.
And - oh miracle - it was not immediately false flagged by bitdefender as a virus this time. Maybe I should zip the installer better ...
Anyways, I hope this will fix it Rolling Eyes
Audio files: 274
PostPosted: Thu Jun 02, 2022 6:54 pm    Post subject: another new one Reply with quote  Mark this post and the followings unread
Aand another new one 2022.6.2.0 - I think it is about 30% faster than a while ago .. and some more stuff ...
Details are @ https://bluehell.nl/blogje/
John_W_Thompson
G2 patch files: 5
PostPosted: Thu Jan 12, 2023 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell I have lost track and have a stupid question. Could one say Wren is sonically the same as Nord Modular G2? Or is it a do not compare situation. Thanks sir.
Audio files: 274
PostPosted: Thu Jan 12, 2023 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure! One can say just about everything!
And nowadays .. oh damn .. let me keep plottix out Smile - just be sure to vote the right thing . erm left thing .. next time Smile
But anywway ... eh .. eh .. I've never tried to make Wren sound like a Nord.
Hmm and that is not 100% true .. just 0.327% or so ...the OSC1/OscPercCS module .. i've made that one listening to Nords!
So eh .. the short answer is : No Smile
Audio files: 274
PostPosted: Thu Jan 12, 2023 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh and btw it is at 2022.12.4.0 now, version wise : https://bluehell.nl/
The blog has some update / revision news .. overall though .. I think Wren to be be finished!
I'm out of ideas and out of plans .. i use it .. just that .. use it :)
John_W_Thompson
G2 patch files: 5
PostPosted: Fri Jan 13, 2023 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
THANKS SO MUCH!
Audio files: 274
PostPosted: Tue Feb 07, 2023 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
The input module was not working, made a new Wren version to fix that : 2023.2.7.0.
There is some more info @ https://electro-music.com/forum/topic-73740.html
You should be able to obtain this from within Wren itself (menu: Help / Full update ...).
And if not ... see the blog : https://bluehell.nl/blogje/ or the Wiki : https://bluehell.nl/wren/wiki/doku.php?id=download for more info on downloading and installation.
Audio files: 701
PostPosted: Thu Feb 09, 2023 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumright Hail the Master well-done: Hail the Master thumleft
amazing piece of work!
maybe I'll play around with it again someday, but I don't seem to get along with softsynths very well.
Audio files: 274
PostPosted: Thu Feb 09, 2023 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hah, thanks pho Cool
And .. you know .. even when my apartment maybe is, I think, slightly larger than yours .. I do not have that amount of space that you have for hardware Laughing
Also .. the 2023.2.7.0 fix was not ok yet .. made a 2023.2.8.0 as well to repair inputs better Rolling Eyes
