sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Thu Jul 07, 2005 11:00 am Post subject:
Various 'drum machines' for electronic & realistic drums Subject description: Fat Kicks, Snares, Claps, Hi Hats and Percussion. **July 07 - New Drums** |
Firstly, let me say that had there been room in the title line, it would have read '... & semi-realistic drums'. Now that's out of the way, we can move on.
Below are 4 (for now) 'drum machines' that were specifically designed to recreate certain groups of sounds, ie. kicks, snares, claps and percussion. I dare say that you could create similar sounds on all of them (maybe except the clap machine), but each has modules that are best for that type of instrument. They all include multiple oscilators and 'extreme' shaping abilities on each, plus final shaping and output trim too.
Not all of the modules are needed for each sound, so once you have created the sound you want, each patch can be stripped right down for use in a performance to allow more polyphony, as can be seen in my '2am' performance.
<<<edited>>> See below for 1 DSP all-in-one patches, Drum machine and Drum machine v2, with patch/programming explanations/tips.
Note that as there is some irregularity to some of the sounds each time they are triggered, these drum sounds are best suited to being sampled or recorded, as opposed to being played live. Also, they are quite heavy patches - another reason to sample them.
All the 'machines' have been labelled and electronic drum creation is easy, allthough you may like to check out the 'synth secrets' section of the Sound on Sound website (as I did) to help you create more realistic sounds. To help, each 'machine' has a variety of both electronic and (semi) realistic drums created in the different variations, for you to either use or tweak. Some of the patches have convenient morph controls pre-set, allthough some variations have had their morph amounts changed to suit the sound, ie. on the clap machine, there is a single Decay knob set up which alters both the Density and the Tail envelopes by pre-determined amounts, but on some variations I wanted to alter the relationship between their decays.
Kick machine:
Note that as sometimes you may want the envelope click in the sound, use the BeaterOsc for that part of the sound and set the filters so that the HPF is before the amp envelope. As such, not all the parts of the sounds I created are in their 'pre-labelled' postions, ie. the bass may be from the vibration path because I wanted to use something from that path not in the bass path. (See below for attached screenshot)
Snare machine:
Note that the frequency shifters are only needed for more realism (although they can be used otherwise) so there is a handy On/Off switch for it.
Clap machine:
I have to admit that I'm not overly impressed with this patch although it can produce convincing claps. This is definitely a tricky sound to recreate (as you may soon find out). Note that the delay bank is set optimaly for 808 style claps on variation 6. Also note that in general, 808 style claps need more FM and others need less.
Edited >> See below for Percussion machine and now a new Hi hat machine.
Description: |
 Download |
Filename: |
Clap machine.pch2 |
Filesize: |
3.53 KB |
Downloaded: |
2500 Time(s) |
Description: |
 Download |
Filename: |
Snare machine.pch2 |
Filesize: |
3.7 KB |
Downloaded: |
2754 Time(s) |
Description: |
 Download |
Filename: |
Kick machine.pch2 |
Filesize: |
3.45 KB |
Downloaded: |
2704 Time(s) |
sheridan
Audio files: 27
Posted: Thu Jul 07, 2005 11:03 am Post subject:
Percussion machine:
Cowbells, rimshots, bongos, etc. Again, it turns out that percussion is quite tricky for the beginner (me included) to recreate. Check out SOS for help (see main text). Note that as Osc 2 was designed to reproduce vibrations, ie. a narrow band of thick partials, it has 2 Lev Amps to increase it's filtered-down level.
Description: |
Screenshot of the Kick machine patch. |
Filesize: |
224.94 KB |
Viewed: |
39829 Time(s) |
Description: |
Screenshot of the Percussion machine patch. |
Filesize: |
137.44 KB |
Viewed: |
39827 Time(s) |
Description: |
 Download |
Filename: |
PercussionMachin.pch2 |
Filesize: |
4.16 KB |
Downloaded: |
2130 Time(s) |
Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
Posted: Thu Jul 07, 2005 12:10 pm Post subject:
I think the kick machine here is well done. Very nice actually.
The snare too is nice as is the percussion machine.
Though I like the other clap patches you made previously.
This one is far to something clicky not sure though.
It can easily be edited around.
But dont get me wrong great contribution and thank you! |
sheridan
Audio files: 27
Afro88
Audio files: 12
G2 patch files: 79
Posted: Fri Jul 08, 2005 5:56 am Post subject:
Nice drum modules Sheridan. It's great to have the basics of a decent analogue based drum kit in the G2  |
Jason
Posted: Fri Jul 08, 2005 8:59 am Post subject:
Yes I think its awesome this work you did putting it together.
One thing I will say I do like about the new clap setup sheridan is
all the envelopes added. Can really get some more control over it like you were previously speaking of in the other thread. This may sound silly to some, but I have always had an extreme liking for all the 808 hats.
I think the G2 can make good emulations 808 sounds but I am not sure how well one could make an open 909 HH. I have yet to try , but have given it some thought...
Hope your doing ok there in the UK Sheridan!
Crazy times... |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Fri Jul 08, 2005 4:08 pm Post subject:
Jason wrote: | but I am not sure how well one could make an open 909 HH. I have yet to try , but have given it some thought...
Crazy times... |
Correct me if I'm wrong, but I'm pretty sure the 909 open and closed hats come from a ROM sample. I know the ride and crash cymbals do, but I'm pretty sure the hats do as well.
And yes, I hope you and your family/friends are alright Sheridan... crazy times indeed. |
Jason
Posted: Fri Jul 08, 2005 4:27 pm Post subject:
Afro88 wrote: |
Indeed Afro88 this is true. quote from wikipedia
http://en.wikipedia.org/wiki/Roland_TR-909
"The hihats and cymbals are 6-bit samples, compressed and combined with a volume envelope curve to allow slight modification."
For the 909 that is whereas I think the 808 uses a combo of sample and noise osc. Still though I just think getting that sound out of the G2 would be most impressive if possible or even close to possible. That is all I meant  |
ian-s
Joined: Apr 01, 2004 Posts: 2667 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
Posted: Fri Jul 08, 2005 5:23 pm Post subject:
The 808 hats are made from a CMOS HEX inverter configured as 6 square wave oscillators, these are mixed and high pass filtered to produce the metal sound. You can get the actual schematics all over the net. The G2 metal oscillator I think produces a similar tone.
I was at the launch of the TR808 in Sydney (and again some months later in Auckland), it was a combined JP8/TR808 launch. I was impressed when the demo guy programmed ‘Heart ache tonight’ by the Eagles into the 808 in real time but had no idea it would become such a legend. |
Jason
Posted: Fri Jul 08, 2005 5:43 pm Post subject:
g2ian wrote: | The 808 hats are made from a CMOS HEX inverter configured as 6 square wave oscillators, these are mixed and high pass filtered to produce the metal sound. You can get the actual schematics all over the net. The G2 metal oscillator I think produces a similar tone.
Very cool
I love cymbals. |
sheridan
Audio files: 27
Posted: Fri Jul 08, 2005 7:43 pm Post subject:
Funny that you're all talking about hi hats... because here's my 'Hi hat machine'! It has two methods of creating the many enharmonic partials needed: the six square wave method mentioned above or 3 part FM - Note that when using FM, turn off Oscs 1, 3 and 5 as shown in some variations. There are three seperate audio paths, each with filtering and envelopes plus the usual final shaping modules.
I have been a bit lazy with the 6 square wave setup (only 1 set of variables) as it is a bit of a nightmare having to tune each one by ear and this set took me a while to find! I have as usual created 8 variations. I am very pleased with this patch and will surely be using these hats!
Note that there are two 'Level Sequencers': 1 is for decay (open/closed) the other is for level and is also connected to the filters.
Below is a screen shot.
Have fun!
p.s. thanks for your kind thoughts guys - I think most of London is back to normal now... us Brits are very resiliant!
Description: |
Screenshot of the Hi hat machine patch. |
Filesize: |
115.91 KB |
Viewed: |
39719 Time(s) |
Description: |
 Download |
Filename: |
Hi hat machine.pch2 |
Filesize: |
3.77 KB |
Downloaded: |
2065 Time(s) |
Jason
Posted: Fri Jul 08, 2005 8:06 pm Post subject:
Sweet !!!
Hey Sheridan , these are some of the best Hats ever, no joke!
Thanks  |
sheridan
Audio files: 27
Posted: Fri Jul 08, 2005 8:15 pm Post subject:
Yeah thanks, I'm pretty impressed myself! Add a touch of reverb and they're even better!!
Not bad for a modular noob!  |
Roland Kuit
Joined: Sep 29, 2003 Posts: 1091 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Sat Aug 13, 2005 1:54 pm Post subject:
Nice work Sher, Thanx! |
sheridan
Audio files: 27
Posted: Fri Feb 10, 2006 12:54 pm Post subject:
Drum machine! |
Hi there everyone .
At last, I have combined most of the above patches into one fairly cheap (DSP) patch - just the basics, mind, but it still sounds good:
Drum machine with Kick, Clap, Snare, and Hi Hats.
<<<edited>>>
For quick variations on the different drum sounds, use variation 8 which has morph controls set up. I have made 7 variations with a variety of sounds for you to get started with straight away.
Points to note:
Snare drum and Hi Hats can have level information as well.
To get different Hi Hat sounds, tweak the various (Yellow) Pulse Width and FM knobs first... well, just tweak all the knobs!!! I'm sure you can work it out.
<<<edited>>>
Oh yeah, I have tweaked the patch to get it to 1 DSP now. Yay!
That's about it. Have fun!
Description: |
Drum machine with Kick, Clap, Snare, and Hi Hats (now just 1 DSP). |
 Download |
Filename: |
Drum machine.pch2 |
Filesize: |
6.59 KB |
Downloaded: |
2052 Time(s) |
Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk Last edited by sheridan on Wed Jul 18, 2007 1:23 pm; edited 3 times in total |
cebec
G2 patch files: 31
Posted: Fri Feb 10, 2006 2:40 pm Post subject:
i'd like to take the opportunity to thank you for the excellent quality of these drum sounds. i was astounded, recently, when i was going through my archive and came across the individual patches. thanks! |
Joined: Jan 31, 2003 Posts: 18061 Location: Durham, NC
Audio files: 183
Posted: Fri Feb 10, 2006 3:44 pm Post subject:
Yes. Good work, Sheridan. Thanks much...  _________________ --Howard
my music and other stuff |
Jason
Posted: Fri Feb 10, 2006 5:42 pm Post subject:
yes these are some of the best on our planet earth.
I cant wait to see what changed in the new version and indeed Thank You Sheridan |
sawtooth
Posted: Wed Apr 12, 2006 3:11 am Post subject:
Really amazing drums! Thanks a lot Sheridan.  |
hoshigoshi
G2 patch files: 4
Posted: Sat Feb 24, 2007 3:15 pm Post subject:
This is incredible, great patch!!
i want to ask you a question I am doing an Emulation of the TR-808 on the G2 atm and i`ve just checked your 808 claps patch and it`s really great. May i use it for my TR-808 Patch with your permission?
Best,
Hosh |
sheridan
Audio files: 27
Posted: Sat Feb 24, 2007 9:00 pm Post subject:
Thanks Hosh
You are most welcome to use any of these sounds/patches for your own creations. _________________
Sheridan
http://www.nitetimeproductions.co.uk |
hoshigoshi
G2 patch files: 4
gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Mon Feb 26, 2007 2:03 pm Post subject:
Quote: | 'd like to take the opportunity to thank you for the excellent quality of these drum sounds. i was astounded, recently, when i was going through my archive and came across the individual patches. thanks! | Cebec
I feel the same....EXCELLENT 808 Clap  |
sheridan
Audio files: 27
Posted: Wed Jul 18, 2007 1:21 pm Post subject:
New improved version of Drum machine!! Still only 1 DSP |
Hey guys,
It's been a while since I posted here, but seeing as I have been using modified Drum machine patches in my performances, I thought I'd post an updated and improved version for you.
Adjustments have been made to the Kick and Snare to allow a much wider variation in drum sounds. You can now change the shape of the pitch and amp envelopes - a huge improvement. Also, an Oscillator B for the kick beater allows for a wider range of sounds.
The snare now features an eq for the noise element, which can change the sound and feel dramatically as you will hear from the examples. Also, the kick sequencer level output is patched to various inputs to allow control over pitch, filter and envelope shape as the sequencer plays.
Also, the signal flow has been altered so that the filters come after the amp envs, so they filter out resyncing clicks, producing cleaner sounds. There aren't so many new modules, but there are 32 newly programmed drum sounds in the 8 variations that you are all welcome to use/modify in your own patches.
Morph controls are only set up in variations 1 and 8 as the other variations had more significant tweaks. Below is an .mp3 of the 8 breakbeats from the patch and the patch itself.
Enjoy.
<<Edited>>
Drum programming tips for this patch:
The level output from the Kick sequencer is 'hardwired' to the AM input of the kick's two amp envelopes, but you can alter the amount that affects the Amp env shape control and the pitch (there is a LevConv module further down that allows higher/lower pitches from higher levels). Set the Bass Osc pitch mod to 0 then set the frequency to the lowest frequency you want the kick to have, ie. the pitch it ends on. Then set the pitch mod to the value/frequency that you want the highest (initial) pitch to be (the knock of the kick). Next, adjust the Pitch Env decay and the Env Shape control below to taste - the Pitch Env decay should generally be shorter than the Amp Env decay. Using different oscillator shapes for the BeaterOsc module can dramatically shape the sound of the initial transients of the kick, as can adjusting it's Amp env decay (short values are best for this).
The Pulse and Delay modules and the Crack Env & HPF of the clap should generally be left (near) where they are for authentic clap sounds, but adjusting the Density and Clap LPF allows for variation. The Noise colour and OscC1 pitch and/or FM amount controls also have an effect, with higher FM amounts producing cleaner, more noise-based claps and lower amounts allowing the oscillator pitch to be heard, creating dirtier claps.
Adjusting the snare is best done starting with just the lower oscillator being audible - set the lowest frequency for your snare. Next, turn on the second oscillator and adjust the frequency until a nice relationship between the two is heard. At this point, experiment with the pitch input amounts and the pitch env. Generally, the lower frequency oscillator should have a slightly longer Amp decay than the other one. Next, add the noise - the extensive filter section allows for exact bands of noise to be throughput. Don't be afraid to use large quantities of boost on the Eq as it is only affecting the noise (1kHz to 5kHz is usually most effective). Finally, the snare level is patched to the Noise LPF mod input, so the snare sound can brighten with higher levels.
There are two main ways to 'tune' the Hi hats. Either adjusting the pitch, FM amount, Shape, and/or the shape input amount controls on the two oscillator circuits (FM 1 & FM2) individually and then combining them, or adjusting them with them all sounding. Either way is good, but you will soon realise that some frequencies just don't work together. Note Osc3 feeds all the other oscillators' shape inputs, so adjusting its pitch will affect all of the others' sounds. When you have a nice sound, it's time to tweak it in the filter section. All the sound goes through the first BPF, so don't cut out too much with the resonance - think of it like a tone control. Use the HPF below to 'zoom in' on the frequencies you want and boost them with the resonance. The WaveWrapper helps to add mettalic...er..ness, but go easy on the amount... it soon gets too much. The final HPF has the level output patched to it, so quieter (or louder, depending on the adjoining LevConv module) notes can have less lower frequencies. Finally the Amp env Decay mod input sets the difference between the decays of the closed and open hi hats - The decay value is the decay of the closed hats and the modulation value is the extra decay added for the open hats.
Go on, have a tweak!! See what you can come up with... it's great fun!
<<Edited>>
Description: |
8 break beats featured in the new Drum machine.pch 1.02 MB 01:07 |
 Download |
Filename: |
Drum machine v2 drums.mp3 |
Filesize: |
1.03 MB |
Downloaded: |
1288 Time(s) |
Description: |
Drum machine v2 - Features fully programmable drum machine with kicks, claps, hats, snares, sequencers and 32 drum sounds programmed in the 8 variations |
 Download |
Filename: |
Drum machine v2.pch2 |
Filesize: |
6.59 KB |
Downloaded: |
2472 Time(s) |
Sheridan
http://www.nitetimeproductions.co.uk Last edited by sheridan on Tue Aug 28, 2007 7:11 am; edited 6 times in total |
gomidas
G2 patch files: 6
Posted: Thu Jul 19, 2007 7:01 am Post subject:
Hey Sheridan! It's getting better and better....I'm really into snare drum sounds and I must say you are making some of the BEST one for the G2 (kick,hh,clap&perc as well)..yes, THANK YOU for that !!!
The way you tweak the snare on Variation 3, is the way I like, those little cracky snappy sounds....mmmmh I love them.
Thank you very much for this impressive work...and now let's bang IT....
PS:Sheridan I recently came across your incredible Helicopter v3 Patch, and I still can't believe that's my G2 that is giving me this sound...now tell, HOW DO YOU USE SAMPLING WITH THE G2??????  |
