bakuna
Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
G2 patch files: 626
Posted: Tue May 30, 2006 12:05 am Post subject:
Re: Experienced Patcher's help needed |
bakuna wrote: | can above be achieved ? |
The G2 was designed by keyboard musicians and falls short when it comes to use with guitar style controllers.
I can think of how to do what you want, but it would be limited to 4 strings/pads and use every slot of the G2.
It is a pity that the transition from G1 to G2 didn't include another two (or four) slots. |
bakuna
Posted: Tue May 30, 2006 5:36 am Post subject:
to be able to play control 4 strings is already big leap forward . while i was waiting for somebody to respond i patched something up with my limiting patching abilities but not quite what i described . it would be awesome if you could share how it would be done !
Art |
Kassen
Posted: Tue May 30, 2006 7:03 am Post subject:
I think it would be a lot easier to figure out exactly what you need if you would use complete sentences and didn't asume everybody knew all the details about this controler's midi implementation. Right now your post is very hard to read yet gives very little information.
For example; do all those strings have their own MIDI channel? Does this Korg have a MIDI-merge function? Doyou want just one pad to "strum" all strings at the same time or are we looking for a more flamengo style of playing? _________________ Kassen |
G2 patch files: 626
Posted: Tue May 30, 2006 7:51 am Post subject:
What I was thinking was to have 4 identical monophonic patches loaded into ABC and D slots. Assuming that the G10 does transmit on a separate midi channel for each string, each of the 4 slots should respond to note info for one string. Next step is to disconnect gate (turn off KBD button on envelopes) and velocity from the patch and replace with gate/velocity outputs of a MIDI NoteRcv module, one for each slot. Set the NoteRcv MIDI channel and note number to match those produced by four pads and you should be set. Save the whole thing as a performance.
The problem with going to a single polyphonic patch is that there is no control of the voice allocation, so you would not know which string was going to be triggered by a given pad. You would also loose individual bend data, limiting playing style. |
bakuna
Posted: Tue May 30, 2006 10:52 am Post subject:
G10 does transmit on a separate midi channel for each string , no matter how difficult it sounds what Gian suggests i'm gonna try tonight to execute it .
[quote]Does this Korg have a MIDI-merge function?
Korg pads can transmit/receive different cc# on each pad .i'm not sure if it has midi merge function . if i pick single not on the G10 NECK i wand to be able to triger same note with Korg pad .its just playing with two hands is more interesting then with one. not necessarily Flamengo type of strumming i want to achieve , i'd be more then happy with monophonic trigger . but anyhow it sounds that Gian uderstood what i'm trying to do.
i will write back tomorrow / |
Fozzie
G2 patch files: 49
Posted: Tue May 30, 2006 11:09 am Post subject:
Do I understand you correctly if I think you want to determine the pitch of the notes by the G10 and use the trigger signals from the pads? That would be quite easy on a G2, but you need a midi merge device (for combining both midi signals in the G2 midi-in) and the problem G2ian pointed out with the 6 strings / 4 slots. |
bakuna
Posted: Wed May 31, 2006 8:29 am Post subject:
thats what i want to do . is it a standard MIDI merge merger i need or theres any particular one ? and how do i integrate it ? |
Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
bakuna
Posted: Wed May 31, 2006 11:46 am Post subject:
thx.
i'm using midiman 8x8 with cubase sx . any idea of possible routings? |
G2 patch files: 626
Posted: Wed May 31, 2006 12:05 pm Post subject:
The padKontrol does not seem to have a soft through or merge (unless a computer is connected, then the in acts as a MIDI to USB).
How about the G10? If it does not have a dedicated MIDI Through connector than it may have a merger built in. Check the manual first. |
bakuna
G2 patch files: 626
Posted: Wed May 31, 2006 4:03 pm Post subject:
Cool
Glad you got it working, sounds good. |
bakuna
Posted: Thu Jun 01, 2006 4:17 am Post subject:
You have some good work done . i would like to think something for Nagasaki ... |
bakuna
Posted: Fri Jun 02, 2006 6:45 am Post subject:
i would be great if someone can finalize it . Gian , if G10 has MIDI through how can it be possible to implement what i'm trying to do ? if it is not possible then i will stop posting and let you guys get on with your doings |
G2 patch files: 626
Posted: Fri Jun 02, 2006 1:41 pm Post subject:
bakuna wrote: | if G10 has MIDI through how can it be possible to implement what i'm trying to do ? |
Some Yamaha devices have a built in merge which duplicates midi info sent to the in port, on the out port. This saves the space and cost of the third midi connector. If the G10 has a dedicated through port then it is less likely to have the built in merge but check the manual.
The attached performance is a simplified version of what I described earlier, if you manage to get MIDI data from both devices into the G2.
The G2 keyboard wont play this, it will accept triggers on MIDI channel 5 from 4 pads set to E4,F4,F#4,G4
Programming variations will not be simple, you would need to copy to each of the other three slots. On the plus side, you can have different sounds for each string.
Description: |
set G10 midi to channel 1,2,3 and 4 |
Download |
Filename: |
PadKontrolG10-1.prf2 |
Filesize: |
5.98 KB |
Downloaded: |
1443 Time(s) |
bakuna
Posted: Sat Jun 03, 2006 7:36 am Post subject:
thx for the prf. i'll try to work it tonight
regards |
