USB goes away in Windows
Page 1 of 1 [5 Posts]
cappy2112
PostPosted: Wed Feb 22, 2006 4:03 pm    Post subject: USB goes away in Windows Reply with quote  Mark this post and the followings unread
[Editor's note: This topic was split from anther topic - http://electro-music.com/forum/topic-10153.html . I thought it would be of general interest. Sorry it may be a little difficult to follow. --mosc]
DrJustice wrote:
Hey cappy, thanks for the concern!
cappy2112 wrote:
Any chance you've got a loose usb connector on the midi interfaces (at least on the midisport)?
I don't think so - same result with the Delta 1010 and the midisport with different MIDI cables and PCs. But it's the right place to start, thinking of the age old words of wisdom "always suspect the cable"... Must be a quirk in the earth magnetism at my location or something Razz
However, I may have a solution coming up. I'll post a report as soon as I know how it goes.
DJ
When I close my laptop overnight, then re-open it with the G2 USB connected, it can't see the G2 any more. I have to unplug the G2 from the USB hub (or reboot), before the G2 can be seen.
I dont know why, but this is how I get around the problem.
klangumsetzer
Audio files: 36
PostPosted: Thu Feb 23, 2006 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
access released os updates for the virus a and b after they were discontinued. also, patches made on a virus a can be used with the ti and vice versa (without the enhanced features, of course).
regarding problems with midi and windows : there is a maximum number of entries in the registry for 32 bit audio and midi drivers. Shocked
for more infos and remedy, please look at: http://www.createdigitalmusic.com/forums.html?option=com_content&task=view&id=1176&Itemid=44
edit: there is a utility available from m-audio (formerly midiman) here: http://www.m-audio.com/forums.html?do=support.drivers&f=84&dl=yes
hope this helps
best regards
eike
Audio files: 222
PostPosted: Thu Feb 23, 2006 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
It's not possible to move posts back to where they came from. Embarassed
klangumsetzer
Audio files: 36
PostPosted: Thu Feb 23, 2006 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm a little confused myself now. Confused
maybe you can link to the new thread? if you haven't done so already
best regards
eike
Audio files: 222
PostPosted: Thu Feb 23, 2006 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Arrgggg... It will be a long time before I do this again.
