Phase inversion and filtered noise
Page 1 of 1 [2 Posts]
Falk
G2 patch files: 29
PostPosted: Tue Mar 14, 2006 12:20 pm    Post subject: Phase inversion and filtered noise Reply with quote  Mark this post and the followings unread
Who among us haven't filtered noise through high resonant bandpass filter to create a breathy organ sound? Well, I have anyway...
24db filter with bandpass at 6.6% was just a bit more then I could afford when striving for 4 voices (with 3 resonant peaks) on a micro.
The classic filter at 5.5% is mostly bandpass at high resonance and this lead to this idea. By feeding one LPF with the straight noise signal and the other LPF with a phase inverted signal the 'bass tails' cancel out.
Not a huge win by any account but it got me under 25%
By careful choice of phase and levels it can be further extended to more resonant peaks.
Regards
Falk
FilterNoise.pch
 Filename:  FilterNoise.pch
 Filesize:  1.31 KB
 Downloaded:  458 Time(s)
Falk
G2 patch files: 29
PostPosted: Thu Mar 16, 2006 6:59 am    Post subject: Just another example Reply with quote  Mark this post and the followings unread
Using three classic filters and a X-fader to make sure that the 'bass tails' cancel out.
Mod wheel: mix of 2:nd and 3:d octave
1:st knob: pitch env amount
2:nd knob: pitch env release
FilterNoise2.pch
 Filename:  FilterNoise2.pch
 Filesize:  1.58 KB
 Downloaded:  438 Time(s)
