cappy2112
Joined: Dec 24, 2004 Posts: 2500 Location: San Jose, California
Posted: Mon Apr 24, 2006 2:07 pm Post subject:
FW: FREE Album tracks- featuring a Nord Modular |
Subject: [OT]Noxia - Album free giveaway.
Message-ID: <007e01c66722>
(with permission from the Author/composer)
Thanks for the feedback, yes feel free to post them on the NM list
if you want. The tracks that use the NM is (From memory):
Update-April 27, 2006
The author has changed his mind
Reply-To: Rikard <rikard>
To:
Date: Apr 27, 2006 12:26 AM
Subject: Re: Noxia
Hi Tony,
Yes, It is temporarily down. I got in touch with a record company that
showed interest so they asked me to delete the files.
Hey (Sorry for the plug),
I am quite sure I will regret what I am about to do, but I am
tired of waiting for the recordcompany to release this. And
I am turning more and more away from this type of music, so
I have decided to give away this "album" for free:
LINK REMOVED
The gear used: Clavia Nord Modular, Waldorf Microwave XT
Alesis Andromeda A6, Hartmann Neuron, Akai Z8, Roland
MKS-80, Yamaha FS1R, Korg Wavestation, Modcan modular,
SCI Prophet VS, SCI Prophet 5, Boss AW-3 pedal
Recorded through Alesis AI3/Creamware Pulsar2, no mixer
has been used. Mixed in Nuendo, tracked in Cubase VST.
Here´s a more complete list of the sounds:
Track 1: begins with Hartmann Neuron, and after that at 1:16 Alesis A6 kicks in
Modcan is used for the various effects. Human speech like sounds = Modcan
through Boss AW-3 pedal.
Track 2: Hartmann Neuron & Korg Wavestation. Drums are Z8 (samples)
over 3 or 4 different kits where used in different layers. Kraftwerk like bass
is Z8 (sample is ARP2600 bass). Choirs are Z8. Arpeggio is probably
A6. Whitenoise is Modcan. Vocoder is Korg MS2000. The voice is
computer generated. The Lead is Yamaha FS1R. Drums are Korg WS
and Linndrum samples.
Track 3: High Arpeggio is Prophet VS, Bass is Clavia NM, second and
third arpeggio is Clavia NM. Choir staccatos are A6. Drums are samples.
Track 4: Bass line is A6, Lead lines are MS2000, Drums are samples.
Disharmonic lead is Clavia NM. Effect synth sweeps are MS2000.
Track 5: Choir is Andromeda, Bassline is also the Andy. all effects
are Modcan, Guitar lead is Korg WS. Bloopy sequencer is Clavia NM.
Lead line is Clavia NM I think .. Techno stab lead in pause is Waldorf
Microwave XT. The drums are samples.
Track 6: Andromeda strings (three separate sounds played in different
octaves recorded separate and faded separately to get another kind of
phasing effect), the sample & hold bass is Modcan (sampled
and Z8 filters doing the bandpass effect). Ice lead is a mix of Korg MS2000
and Korg WS. Whitenoises are Modcan. Some up&down going arpeggios
are Oberheim Matrix 1000. A lot of MKS-80 in the middle pause part.
Lead in the end of track is Modcan. Drums are samples.
Track 7 & 8: The voice is Clavia NM. Deep drum is Z8 recorded many times
over and over with reverb. Strings are from the XX-most wanted stringmachines
sample library. Arpeggio strings are mix of samples and Korg WS. Big Vangelis horn
is Clavia NM. Digital sounding arpeggio in background is Modcan. Noises and effects
are Modcan. Drums are Linndrum samples. Bassline is Microwave XT.
strings are Korg WS. Lead staccato line is Prophet 5 mixed with samples.
Pad in the end of the track is Z8 sample.
Track 9: Strings are samples, drumloop is a sample. The clockwork sounds are Cubase VST effect which I recorded during live twisting the VST effect knobs. Bassline is Clavia NM FM bass. Human vowel sounds are Modcan through
Boss AW-3 pedal. Church organ chords are Z8. Metallic sweep is Korg MS2000. Lead line in the mid/end part is MKS-80. Arpeggio is Yamaha FS1R and so are the "ohohow" choir chords. The Glittery ending sound is Modcan S&H.
Track 10 & 11: Strings are Andromeda & Korg WS. The jungle effects are Modcan. Drums are a drumloop. Bassline is Modcan and so is the lead blipblop sound. Additional drums beyond the 4:50 mark are Linndrum samples. Various Arpeggios are clavia NM (I have two or three running in the background). Brass arpeggio is also Clavia NM I think .. High strings are Andromeda.
Track 12: All strings are Korg WS, Drums are samples. Bassline is Clavia NM. The brass section is samples. Vangelis horn is again Clavia NM. Little blirpy arpeggio in the background is Andromeda. The Choir is Andromeda.
Track 13: Hi hat percussion and zip zap sounds are Modcan. Drums are a loop time stretched a lot and cut into pieces and re arranged. Bass is a sample of a fretless bass (Z . Weird Melodies are modcan recorded and then turned backwards and time stretched with different time settings. Some lines might be recorded with reverb forwards and then stretched and turned backwards. Last edited by cappy2112 on Thu Apr 27, 2006 8:50 am; edited 1 time in total |
Gothboy
Joined: Feb 21, 2006 Posts: 372 Location: Santa Monica, Ca.
Posted: Wed Apr 26, 2006 3:20 pm Post subject:
Ummm......the link you have provided doesn't work. _________________ Apple Mac Pro 2019 3.2 GHz 16-Core Intel Xeon W
96 GB Ram
15.6 Sequoia
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ |
cappy2112
Posted: Wed Apr 26, 2006 3:29 pm Post subject:
| Gothboy wrote: | | Ummm......the link you have provided doesn't work. |
It worked for 1 day from the (ORIGINAL) post, long enough for me to download
the mp3's. I have to presume the author pulled the files for some reason. |
