DJQUIRK
Posted: Wed Aug 23, 2006 3:42 pm Post subject:
SWITCHES Subject description: DO I HAVE THE RIGHT ONES???? |
| I gave the guy at the local supply house here in Atlanta the parts list from Ray's site for the sound lab. At the time I didn't know much (still don't) and just assumed he would give me the right stuff. Now as I'm assembling my SLMS I've noticed(way late in the game) that all my switches have 3 contacts where as most of the switches on the panel wiring diagram have only 2. Did I get the wrong ones? And if so, can I make them work??Thanks..... |
bigtex
Joined: Mar 30, 2006 Posts: 323 Location: Cupertino, California
Posted: Wed Aug 23, 2006 6:09 pm Post subject:
Yes, those switches will do. You'll want to use the middle (common) pin from the switch, and then one of the sides. You can leave the other side unconnected. If you have any kind of multimeter, hook it up to the switch pins and flip the switch back and forth. Try to get an idea for what's going on in there.
Here, take a look at this diagram:
The way it is pictured, the switch lever is to the right, and on the inside it is making a connection between the middle pin and the left pin. So when you flip the switch to the left, it makes a connection between the middle pin and the right side pin. There's no magic it's just a mechanical device.
Hope this helps and good luck building your Sound Lab! |
adhdboy
Posted: Thu Aug 24, 2006 10:09 pm Post subject:
Here is some more switch information. Subject description: Information about different types of switches |
Like big tex says you can use any switch that has enough poles and throws for your application. Here is some more switch info...
http://www.musicfromouterspace.com/analogsynth/oddsandends.html#SWITCHINFO
ADHDBOY _________________ There 10 kinds of people in this world that understand binary those that do and those that don't. |
DJQUIRK
Posted: Fri Aug 25, 2006 9:01 pm Post subject:
THANKS!!!!!!!! |
| MUCHAS GRACIAS!!!! THIS FORUM GIVES ME A WARM FUZZY............. |
