Errors during build
Page 1 of 1 [9 Posts]
Blind Irishman
PostPosted: Fri Sep 01, 2006 10:32 pm    Post subject: Errors during build Reply with quote  Mark this post and the followings unread
Hello! I heard about ChucK a long while back and now I'm interested in trying it out!
However, I'm getting errors when I build it:
Code:
$ make linux-alsa
make -f makefile.alsa
make[1]: Entering directory `/home/blind/chuck-1.2.0.6/src'
bison -dv -b chuck chuck.y
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck.tab.c
flex -ochuck.yy.c chuck.lex
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck.yy.c
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_absyn.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_parse.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_errmsg.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_frame.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_symbol.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_table.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_utils.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_vm.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_instr.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_scan.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_type.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_emit.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_compile.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_dl.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_oo.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_lang.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_ugen.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_main.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_otf.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_stats.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_bbq.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_shell.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_console.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ chuck_globals.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ digiio_rtaudio.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ hidio_sdl.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ midiio_rtmidi.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ rtaudio.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ rtmidi.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ ugen_osc.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ ugen_filter.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ ugen_stk.cpp
gcc -D__LINUX_ALSA__ -O3 -c -D__CK_SNDFILE_NATIVE__ ugen_xxx.cpp
ugen_xxx.cpp:43:21: error: sndfile.h: No such file or directory
ugen_xxx.cpp:1516: error: ISO C++ forbids declaration of 'SNDFILE' with no type
ugen_xxx.cpp:1516: error: expected ';' before '*' token
ugen_xxx.cpp: In constructor 'sndbuf_data::sndbuf_data()':
ugen_xxx.cpp:1548: error: 'fd' was not declared in this scope
ugen_xxx.cpp: In function 'long unsigned int sndbuf_read(sndbuf_data*, long unsigned int, long unsigned int)':
ugen_xxx.cpp:1574: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1586: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1586: error: 'sf_seek' was not declared in this scope
ugen_xxx.cpp:1590: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1590: error: 'sf_readf_float' was not declared in this scope
ugen_xxx.cpp:1600: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1600: error: 'sf_close' was not declared in this scope
ugen_xxx.cpp:1601: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp: In function 'void sndbuf_setpos(sndbuf_data*, double)':
ugen_xxx.cpp:1648: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp: In function 'float sndbuf_sampleAt(sndbuf_data*, long int)':
ugen_xxx.cpp:1668: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp: In function 'void sndbuf_ctrl_read(Chuck_Object*, void*, Chuck_DL_Return*)':
ugen_xxx.cpp:1843: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1845: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1845: error: 'sf_close' was not declared in this scope
ugen_xxx.cpp:1846: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1974: error: 'SF_INFO' was not declared in this scope
ugen_xxx.cpp:1974: error: expected `;' before 'info'
ugen_xxx.cpp:1975: error: 'info' was not declared in this scope
ugen_xxx.cpp:1980: error: 'SF_FORMAT_RAW' was not declared in this scope
ugen_xxx.cpp:1980: error: 'SF_FORMAT_PCM_16' was not declared in this scope
ugen_xxx.cpp:1980: error: 'SF_ENDIAN_CPU' was not declared in this scope
ugen_xxx.cpp:1986: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1986: error: 'SFM_READ' was not declared in this scope
ugen_xxx.cpp:1986: error: 'sf_open' was not declared in this scope
ugen_xxx.cpp:1987: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1987: error: 'sf_error' was not declared in this scope
ugen_xxx.cpp:1991: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1991: error: 'sf_strerror' was not declared in this scope
ugen_xxx.cpp:1992: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:1992: error: 'sf_close' was not declared in this scope
ugen_xxx.cpp:2016: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:2016: error: 'sf_seek' was not declared in this scope
ugen_xxx.cpp:2029: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp:2029: error: 'sf_close' was not declared in this scope
ugen_xxx.cpp:2033: error: 'struct sndbuf_data' has no member named 'fd'
ugen_xxx.cpp: In function 'void sndbuf_cget_valueAt(Chuck_Object*, void*, Chuck_DL_Return*)':
ugen_xxx.cpp:2220: error: 'struct sndbuf_data' has no member named 'fd'
make[1]: *** [ugen_xxx.o] Error 1
make[1]: Leaving directory `/home/blind/chuck-1.2.0.6/src'
make: [linux-alsa] Error 2 (ignored)
Anyone have an idea of whats worng and think they can help?
ge
PostPosted: Fri Sep 01, 2006 10:59 pm    Post subject: Re: Errors during build Reply with quote  Mark this post and the followings unread
Welcome!
Looks like you need to install libsndfile library.
You can probably grab as a package for your system, or install it.
http://www.mega-nerd.com/libsndfile/
Hope this helps.
majutsu
PostPosted: Sun Sep 03, 2006 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't know what linux distro you are using, but if it's debian (/ubuntu/kubuntu/demudi/etc) the deb pack on chuck thread has word for word apt-get instructions to build, including dependencies. you can cut and paste them in the terminal. that should do it.
All phenomena are atoms in association and dissociation.
Gasten
PostPosted: Mon Oct 16, 2006 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello. I got the very same problem (and feedback) too. I'm on Ubuntu (debian) and I try to make with alsa. I've tried to aptitude both libsndfile0 and libsndfile1 from the arcives, and I've tried to build the newest version manually (I think I did it correctly...). Still doesn't work. You talked about a file with specific debian-instructions? Can you link to it? Or can someone else se the problem?
spencer
PostPosted: Mon Oct 16, 2006 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Gasten and Blind Irishman,
make sure you have the package libsndfile1-dev in addition to libsndfile. libsndfile1 just includes the library, where libsndfile1-dev includes the library and header files that chuck needs to build against libsndfile.
I think majutsu was referring to this thread, which I think contains pretty much everything you need to know about building chuck on linux:
http://electro-music.com/forum/topic-13115.html
spencer
majutsu
PostPosted: Mon Oct 16, 2006 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, thank you spencer this is the thread to which i referred. chuck works fabulously on ubuntu. i'm using dapper, edgy eft is coming out in weeks. i'm using chuck, pd, om, soundtracker mostly. very cool distro. i'm learning python now to explore it best. if you are still having problems please let me know. i can almost guarantee a perfect build of chuck on dapper i would think.
Gasten
PostPosted: Tue Oct 17, 2006 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, both chuck alsa and oss works perfectly. I'll try to compile one for Jack too, but that's a lower priority. Now it's time for miniAudicle Smile
"i'm learning python now to explore it best."
Good for you! Python is wonderful! There should really be some kind of on-the-fly-tool/Live Coding-tool to python too. If I learn C/C++ (whatever I need), I maybe do one. (there isn't one, right?)
majutsu
PostPosted: Wed Oct 18, 2006 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
lol i was thinking of a python app for music programming too. i think this would be very cool. i need to learn c++ as well. i need those learning chips they put in your head in the matrix, that would speed this process up a little Very Happy
Gasten
PostPosted: Wed Oct 18, 2006 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Learning-chips is the shit. If I learn Perl, I might even convert "feedback-pl" to python-code. Well.
