Zoomby
Posted: Sat Sep 30, 2006 10:05 am Post subject:
Newbie Problem:Class-A Amp |
can someone explain why this simple amplifier "doesn't work"? The problem is the bandwidth. It acts like a lowpass with cutoff around 500Hz. I tested it between a guitar and a guitar amp.
Here's the circuit:
Bye
Chris
[BlueHell: made your image [ http://img138.imageshack.us/img138/8495/amp1oy3.jpg ] appear in line for easier reference] |
Joined: Apr 03, 2004 Posts: 24496 Location: The Netherlands, Enschede
Posted: Sat Sep 30, 2006 10:30 am Post subject:
The input impedance of the circuit can be roughly estimated to be 47 kOhm (assuming a hFE of 100 for the transistor) and this possibly is too low for a guitar element. In the following link it is suggested that it should be around 1 Meg. Ohm.
You could try to change the emittor resistance to a higher value (like 2k2 or something, or try to replace the transistor with one having a higher hFE value, for instance by using a BC107C (if it exists, otherwise you'll have to look through some datasheets to find another one - both changes may result in clipping though, can't really quickly judge that).
And the promised link is : http://www.geofex.com/Article_Folders/impednc.htm _________________ Jan
Posted: Sat Sep 30, 2006 10:39 am Post subject:
For possible transitor alternatives see : http://www.datasheets.org.uk/search.php?q=BC107C&sType=part - a BC107C does seem to exist with a minimum hFE of 450 which might just be high enough. _________________ Jan
Zoomby
Posted: Sat Sep 30, 2006 10:51 am Post subject:
Thanks for the reply Blue Hell!
I'll take a look a the link you posted! |
Zoomby
Posted: Sat Sep 30, 2006 11:23 am Post subject:
You said the input impedance is 47K. 100 (hFE) * emitter resistor, this is obvious. But why exactly.
Can you explain it easily to a noob? |
Posted: Sat Sep 30, 2006 12:01 pm Post subject:
Couldn't find a nice website to explain it, but I can try myself ...
The hFE tells you what collector current will flow into the transistor for a base current of 1 (whatever units, but lests say micro Amperes). So with a hFE of 100 there will be 100 times as much collector current than there is base current.
In the circuit above the current flowing into the collector will flow out of the device at the emitter where it has to go through the emitter resistor (470 Ohm) into the circuit's ground.
This means that the voltage at the emitter will get higher (Ohm's law). But as for a bipolar NPN tranasistor the base voltage is always about 0.6 Volts higher than the emitter voltage (relatively independent of the base current) the base voltage will go up with the same amount.
The amout being ( hFE + 1) * 1 * 470 [ + 1 is for the base current that also flows into the emitter, * 1 is for the input current that we assumed to be 1]
This means that the base voltage will rise hFE times as much as expeted from the emitter resistance alone (in a case where no collector current would flow), whcih means the "experienced" input impedance has to be hFE (+1, strictly) times higher than the emittor resistance.
This assumes that the resistance between base and emitter of the transistor is near zero, which can be done safely as long as there actually is a base current. _________________ Jan
Macaba
Zoomby
Posted: Sat Sep 30, 2006 3:13 pm Post subject:
Thanks for the great explanation Blue Hell!  |
Posted: Sat Sep 30, 2006 4:33 pm Post subject:
| Zoomby wrote: | Thanks for the great explanation Blue Hell!  |
You're welcome, you got me thinking though
I read everywhere that a guitar amp needs to have high impedance in order to not loose treble ( see here f.i.; that link even explains it).
But really, why is it ?
One would think a current is induced in the pickup coil and a best match against a current source would be a zero impedance current input.
I can see that for a real electric guitar the tone control would ruin this idea ( see here for how some tone controls are implemented). This is sort of odd though as it leads to circuits that are naturally susceptible to hum, it seems.
Anyone who knows the full story ?
Would the tone control get too expensive otherwise maybe (assuming batteries to be too clumsy, it would have to be a passive tone control I'd say). _________________ Jan
Posted: Sun Oct 01, 2006 5:52 am Post subject:
I know the DC resistance of a guitar pickup is in the 2-10K kind of range. I assume that it's impedance would be a lot higher than that, yeah?
The input impedance of this preamp needs to be at least 10 times the output impedance of the guitar, yeah? (I don't know these things for certain, so correct me if I'm wrong Jan) So if it's not, that would stuff with the bandwidth wouldn't it? _________________ What makes a space ours, is what we put there, and what we do there. |
