still have problem
Page 1 of 1 [3 Posts]
tony
PostPosted: Thu Oct 12, 2006 11:25 pm    Post subject:  still have problem
Subject description: about installation
I have try your advice
Iam try with cmd and this result:
%> chuck
[chuck]: no input files... (try --help)
and iam try types
%> cd chuck-1.2.0.7/src/
and then:
%> make
[chuck build]: please use one of the following configurations:
make linux-alsa, make linux-jack, make linux-oss,
make osx-ppc, make osx-intel, make win32
%> make win32
but I have error messages
like Error make win 32 So what should I do
.2)Iam try use mini-audicle and can work properly
but when Iam tery audicle I cannot access even iam hit audicle.exe in bin
thanks alot I hope you can give advice again
PostPosted: Fri Oct 13, 2006 4:41 am    Post subject: Re: still have problem
Hi, Tony!
%> chuck
Yes. This is right. ChucK needs input files.
ChucK by itself does not do anything, it needs one or more .ck files to tell it what to do. You use it like this;
chuck my_program.ck
When you don't tell it what files to use it doesn't know what to do and you get a error like this.
The good news is that in the /examples directory there are example files to try out. Did you copy chuck.exe to the /windows/system32/ directory? In that case it should be installed properly and the next thing to do is learning how to use it.
and iam try types
and then:
%> make
%> make win32
Don't worry about that. That stuff is to compile ChucK yourself, you don't need to do that on Windows.
Ok, I am verry sorry but I don't understand this question and I'm not so sure how to help you with it. Sorry about that.
kijjaz
PostPosted: Fri Oct 13, 2006 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
i guess you need to have GLUT for windows.
have you installed GLUT yet?
(it's needed for running Audicle)
now the page http://audicle.cs.princeton.edu/release/ points to a place to
download GLUT at http://soundlab.cs.princeton.edu/software/sndpeek/files/glut37beta_win32.zip
and how is miniAudicle?
can you play something or make some sound from miniAudicle already?
actually that is the same as using chuck in cmd (command line)
with chuck shell.. but miniAudicle would give you more comfort for now.
