MPF102 replacement
Page 1 of 1 [3 Posts]
rubendelacosta
PostPosted: Sun Nov 12, 2006 2:50 pm    Post subject: MPF102 replacement Reply with quote  Mark this post and the followings unread
hi again!
I didn't found the MPF102 transistor but i found the BF245A and it looks like a good replacer. I think they have the same pin out, but my knowledge on electronics is too short for me to be shure of anything....
so...anyone can se anything wrong with this replacement?
here's the datasheets:
BF245: http://www.ortodoxism.ro/datasheets/philips/BF245A-B-C_2.pdf
MPF102: http://pubpages.unh.edu/~aperkins/pdf/MPF-devices/MPF102.pdf
thank you, rubens.
softfin
PostPosted: Thu Dec 21, 2006 2:32 am    Post subject: mpf102 Reply with quote  Mark this post and the followings unread
It should be fine. I believe the BF245A is also higher quality than the mpf102.
I'm not completely sure is it an exact replacement, but it should be close enough. Good luck with your projects Smile
PostPosted: Thu Dec 21, 2006 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not great at honing in on the crucial stats either, but that's the one I'd try.
