PCB protection
Page 1 of 1 [6 Posts]
nisios
PostPosted: Mon Nov 27, 2006 2:32 pm    Post subject: PCB protection Reply with quote  Mark this post and the followings unread
Hi everyone.
What is the best method to protect pcbs from oxidation?
I think your answers will be spray coating but that raises another question......do i spray it before or after soldering? is it possible to solder throu the coating? And what about brands?
Why is the dove a symbol of peace?
The pillow has a lot more feathers without that dangerous beak.
PostPosted: Wed Nov 29, 2006 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Normally you really don't need to conformal coat a board unless you are in a VERY high humidity environment. Otherwise, your boards will last years without coating, especially if they incorporate solder mask.
If you DO conformal coat the boards, with spray or brush on type, you generally do it after you solder all you components. First, clean the board with degreasing agent or denatured alcohol. If there are IC's that are socketed, then pull the IC's from their sockets. If you have any connectors, then mask them. You don't want coating in those areas. Mask the sockets with masking tape also. Spray your coating, let dry throughally then reinstall the socketed IC's.
Bill
nisios
PostPosted: Wed Nov 29, 2006 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tips.
I dont know, but i made a couple of boards and after 2 weeks they were clearly oxidating.....nothing very serious but in a couple of years there would be a problem. Now imagine i do as you told and a a component needs to be replaced. Is there any problem....unsoldering with coating?
PostPosted: Wed Nov 29, 2006 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you are using thru-hole parts, you shouldn't have any problem at all. Some very small surface mount devices may give you a bad solder joint if replaced, but you should'nt have a problem if you can flux & re-tin those areas before dropping in a new part.
toppobrillo
PostPosted: Wed Nov 29, 2006 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
you can tin plate the boards which is easy and works well. another alternative is to wick solder over all the traces, easy to do a light coating..
also you can use clear spray lacquer.
PostPosted: Thu Nov 30, 2006 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
No, not a big problem BUT I personally strip the coating off the bad part with using alcohol first, then remove and replace the defective part, then touch up the coating with a small brush. If you replace the part with coating on the pads, it gets messy. You want a CLEAN solder joint.
ALSO, ONE THING ABOUT COATING, YOU HAVE TO BAKE THE BOARD TO COMPLETELY DRY THE CIRCUIT CARD OR ELSE YOU WILL JUST TRAP MOISTURE IN THE BOARD WITH THE COATING ....
SO, CLEAN, BAKE DRY THEN COAT THE BOARD ....
I hope these tip help you ....
I am curious though, how or where were these boards that had the oxidation build up so quickly?
Bill
