unquantize
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Dec 18, 2006 12:05 am    Post subject: unquantize Reply with quote  Mark this post and the followings unread
Sort of the opposite of a time quantizer. Use the VA to make N copies of a oscillator with voice# indexing a random offset which is then applied to the pitch change time (via modulated logic delay & s+h) and the glide rate (using LP filter as VC glide). The random offset also detunes each oscillator.
The idea was to emulate the looser timing of ensembles or multitracking.
unQuant.pch2
experiment with time shifting
 Filename:  unQuant.pch2
 Filesize:  2.2 KB
 Downloaded:  1795 Time(s)
