Another approach at sequencing
Page 1 of 1 [7 Posts]
Audio files: 297
PostPosted: Sat Jan 13, 2007 1:50 pm    Post subject: Another approach at sequencing Reply with quote  Mark this post and the followings unread
I had this idea that it would be nice to have a sequencer with small fragments in it and then run a sequencer over that to sequence the fragments. The top level sequencer then needs a start position and a count.
Building it I also added a repeat count. This is not really a finished patch, but merely an illustration of an idea.
A backwards option for the fragments would maybe be nice and not so hard to implement, maybe I'll just do that later.
07-005-001.pch2
A sequencer idea, see forum post for details.
 Filename:  07-005-001.pch2
 Filesize:  4.21 KB
 Downloaded:  2841 Time(s)
astroid power-up!
PostPosted: Sat Jan 13, 2007 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow
i really need to sit down with this one and try to figure it out
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
Audio files: 224
PostPosted: Sat Jan 13, 2007 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a great idea. There is a great deal to do with this.
In looking at the transpose sequencer going into the chain input of a control sequence is like a unity gain mixer. Who woulda thunk it?
Audio files: 297
PostPosted: Sun Jan 14, 2007 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a better version, in that the 1st note of a fragment has the same length as the others, the count matches the set value, a count of 1 can be used, the thing can run backwards and the triggers are stretched to the length of half a clock cycle.
The repeat counts are still not good it seems though, as if they are sampled at a wrong moment. I'll look into that later.
07-005-002.pch2
Improved version of 07-005-001
 Filename:  07-005-002.pch2
 Filesize:  4.59 KB
 Downloaded:  2756 Time(s)
Audio files: 224
PostPosted: Mon Jan 15, 2007 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Audio files: 297
PostPosted: Mon Jan 15, 2007 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I'm going nuts, and and can't count anymore, something seems still off.
But it seems it counts the needed repeats now correctly - after adding a tactical delay.
07-005-003.pch2
3d try
 Filename:  07-005-003.pch2
 Filesize:  6.33 KB
 Downloaded:  2767 Time(s)
Audio files: 297
PostPosted: Tue Jan 30, 2007 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now Entartet
