<on air> Sorry, no program tonight. Chez Mosc
Adding S-trig input to MFOS ADSR?
ericcoleridge
PostPosted: Tue Jan 16, 2007 3:26 pm    Post subject: Adding S-trig input to MFOS ADSR? Reply with quote  Mark this post and the followings unread
I have a simple circuit for an S-trig to V-gate convertor that I got from the Synthesizers.com website. I breadboarded it and it seemed to work well.
But when I power it from the same power header that I'm using for my MFOS ADSR, it doesn't work, and it also shorts(?) the ADSR.
I tried taking both +15, and +5 to power this S-trig convertor, but I tapped it right from the ADSR's header, before the ADSR's decoupling caps.
Is it possible that it needs to be tapped after the caps? This is the only thing I can think of to explain why it works fine when powered from a seperate header. I only thought of this just now, or else I would have tried it out already.
I'd like to have the S-trig circuit all together with the ADSR, and both powered from one header.
Any suggestions?
Thanks
