tonyggg
Posted: Fri Jan 26, 2007 10:51 am Post subject:
Using a Nord Lead 2X with a sequencer? You should know this. |
I have struggled with the Nord Lead 2X midi implementation since purchasing the keyboard and unlike other manufacturers, Clavia chooses to transmit program changes on a second midi channel. They call this channel the "Global" channel which is misleading because it does not behave as a true Global channel, which is typically used when doing sysex dumps etc. It's important to note that the second channel is used only in "Performance" mode. When in "Normal" mode, program changes are transmitted on the same midi channel assigned. This may not seem like a big deal, but when using a sequencer, you either have to record using "All" or "Any" or use two distinct tracks, one assigned to the Nords midi channel, the other assigned to the Nords "Global" channel.
This presents a real problem when using sequencing programs like Steinbergs Cubase if you want to handle everything on one track. Simply put, you have no choice but to use two tracks if you want command of all the Nords controllers from the sequencer.
So just be aware, Nord transmits on two different channels when in "Performance Mode". This implementation just creates more work for the end user. Other manufacturers simply transmit ALL data on the midi channel assigned. Period.
Tony G _________________ http://www.newmusiccanada.com/genres/artist.cfm?Band_Id=10574 |
Posted: Fri Jan 26, 2007 12:43 pm Post subject:
A nice one. I never thought I would see a Nord Lead user hitting the post button at the same rate as vile russian viagraheads.
Listen, we never do excessive crossposting here and the best place to post this in here anyway. If you are a tad annoyed by the engineering feats by the bright minds at Clavia, please ride over to Festung Clavia and tell the guys there. Please do not post this one all over the board. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr Last edited by elektro80 on Fri Jan 26, 2007 12:51 pm; edited 1 time in total |
Joined: Apr 03, 2004 Posts: 24484 Location: The Netherlands, Enschede
Posted: Fri Jan 26, 2007 12:50 pm Post subject:
Tony, would you please stop cross posting ?
I just deleted another four. _________________ Jan
Posted: Fri Jan 26, 2007 1:13 pm Post subject:
Doesn´t the post stating the problem also present the solution to the problem.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
TOTAL
Posted: Wed Feb 28, 2007 12:36 pm Post subject:
Do Clavias communicate with Steinbergs flawlessly? Or should I consider switching to another sequencer?
T |
tonyggg
Posted: Wed Feb 28, 2007 4:42 pm Post subject:
Quote: | Do Clavias communicate with Steinbergs flawlessly? Or should I consider switching to another sequencer? |
It's not a question of the sequencing software, regardless of the product. It's about Clavia not transmitting and receiving ALL midi data, on one channel, when in performance mode. Clavia uses two channels. That's all you need to know when setting up your sequencer for recording. Not a big deal really, but a bit of a surprise and one that took a lot of troubleshooting when things were not working as should. All the other manufacturers that I use transmit and receive pretty much everything on one midi channel, the instruments that can split or multitimber give you more flexibility. But after 25yrs of midi, you would think that Clavia wouldn't mess with the midi protocol. For example, there is no way of changing midi modes in the Nord Lead 2X as well.
As far as Steinberg software goes, I use a number of their products and would recommend them to anyone.  _________________ http://www.newmusiccanada.com/genres/artist.cfm?Band_Id=10574 Last edited by tonyggg on Thu Mar 01, 2007 4:54 am; edited 1 time in total |
TOTAL
Posted: Thu Mar 01, 2007 4:20 am Post subject:
Thanks a lot 4 ur answer and for this post here.
T |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Mar 01, 2007 8:52 am Post subject:
Well Tony, I have to break in...
As written in the earlier thread, I have no problem at all recording Midi data, nor in Cubase nor in ProTools.
I suggest TOTAL to try it out himself.
About the Midi modes, why should Clavia, not making a mono synth themselves, have to worry about these modes? They are not a factory making Midi controller keyboards...
Wout |
TOTAL
Posted: Thu Mar 01, 2007 2:13 pm Post subject:
Okay. I will definitely give it a try. Now something completely different: does NL have a "program change OFF" option (like f.e. Virus TI)?
This matters because apart from home using NL with Cubase, I plan to play it live connected to Yamaha RM1x sequencer/groovebox which on STOP sends some unwanted CCs (outdated OS bug). So far it hasn't been a problem because the Virus has this option. |
tonyggg
TOTAL
Posted: Thu Mar 01, 2007 4:59 pm Post subject:
Gr8! |
Olsen
Posted: Wed Apr 11, 2007 10:17 pm Post subject:
Using a nord lead as a controller. Subject description: Technical and anecdotic short story. |
Hope is not too late to go back to this old topic... But it happen that i just bumped on it and i found it very interesting and may be the solution x my concerns.
First of all let me tell you that since a few years ago to this part i stop reading regular books and i started reading user manuals as if they were novels, with the same emotional envolvement and interest but with much more excitement because now the protagonist is me dealing with the starr that is the device.
If its true that clavia does not make mainly midi controllers out of their masterpieces synths; it is also true that neither Clavia deny this fact and all the Clavia keyboards are mint to be also used as midi controllers, including the electro pianos. Like 99,99% of keyboards produced in between 1985 and 2007 if you find midi ins, outs and thru in the back of your synth even if is a cheap Yamaha or Casio means that are midi controllers(somehow).
Now i go back to my little old problem: I'm arpeggio abuser user, also a sustain pedal abuser, and a wheel pitch/mod abuser; i used to have a K5000 which i sold very good and i bought a NL3 the next day, yes a great deal indeed.. but for my surprise the incredible easy user arpeggiator of the K5000 is found nowhere else... To play arpeggios in any other sound source out of the controller you have to make previous setings up before hand.
With the Kawai K5000 you plug for example the two midi out/ in cable(M-one) to the USB of your mac and play the sounds of your softsynth with the arpegiator of the K5000. or midi out of the K5000 to midi in of whatever other keyboard you want to arpeggiate, play or sustain or change pitch or modulate.
To make this operation with the NL or any other keyboard you have to make a lot of seting and still not have any luck. I never could do this with the NL3 or any other keyboard, and i have try a lot of other brands in the last two months...
The funny thing about this is that the sellers at music stores don't know exactly what the hell i'm talking about and they all say yes, it play arpeggios, then they show me how the arpeggiator works; i remember once in in the Guitarcenter after having this conversation with one seller i took a midi cable and i plugged it from the NL to a Casio WK3500 (my favorite Casio, it has excellent sounds) i set the channels to match and i show the seller that when you press the arpeggio botton of the NL the sound you are playing in the Casio or whatever other brand and model nothing happen, of course the seller started scratching his head and looking at me with confusion and asking me why do you want to play a Casio thru a NL ?.. After that point i lost my pactience and i say ok forget it and i walk out, then i came back and i explained the same seller that synths may complement each other in many different ways...But the guy insisted in the fact that NL is better than Casio by years light, i told the guy that that was not my point, i said i don't care who is better, i'm just trying to use the arpeggiator of the NL to play sounds in other synths or even in the synths that i have in my computer, is that so dificult to understand?
The guy finnaly called other seller and this one was much more square and ignorant that the first one.
Now, two weeks ago i meet one seller in Sam Ash that seemed to be a little genious and he explain me that the operation that i was trying to do was not possible just like eating cake, but recording arpeggio data was totally possible and he show me how, but again is not what i was looking for; i dont want to recor arpeggio data, i want to play arpeggios in my gigs or record'em in my 16 traks individually to over dub'em or whatever else post production i would wish later on...
The guy with sincere humillity told me "i don't know" i don't think this is possible because of a difference of midi language, some GM devices just dont speak or understand the same codes that others and vice versa.
So now that i own a NL3 i'm looking for having a K5000 back. (to complement it with my other synths just because you not only can use the arp with other sounds but also you can tweak other synths and other external sounds from the K5000 in only one matching channel ) so i will keep doing things manually in my recordings and playing less complicated shit in my gigs unless i can find a stand alone arpeggiator and one stand alone knob tweaker...do you know any? do they exist? |
disrupt_the_imc
Joined: Nov 08, 2006 Posts: 28 Location: Northern California
Posted: Wed Apr 11, 2007 11:40 pm Post subject:
It sounds like what your looking for is all available and more in the Access Virus TI. Best sound-engine in existence. Built like brick shit-house, like only europeans can pull off. Arpeggiator is far better than a crappy K5000... |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Apr 12, 2007 2:07 am Post subject:
Re: Using a nord lead as a controller. Subject description: Technical and anecdotic short story. |
Olsen wrote: | ... First of all let me tell you that since a few years ago to this part i stop reading regular books and i started reading user manuals as if they were novels, with the same emotional envolvement and interest but with much more excitement because now the protagonist is me dealing with the starr that is the device. ... |
That's the right thing to do, although... read a 'real' book sometimes too
Most sellers know a lot about selling... About selling synths, about selling washing machines, about selling their grandmother...
It was the big trouble when the Nord Modular Classic hit the market in 1998: the branch didn't understood it!
Quote: | ... so i will keep doing things manually in my recordings and playing less complicated shit in my gigs unless i can find a stand alone arpeggiator and one stand alone knob tweaker...do you know any? do they exist? |
The only nice synth I would suggest is the Nord Modular G2, even the rack version, although I wouldn't recommend it on stage.
It has a rather simple Arpeggiator, but you can use it 4 times in real time, because it has 4 Slots and each Arpeggiator to each Slot can be set different.
The G2 has a complete modular Midi synth part, with Midi Notes In and Out modules. You are able to build your own Arpeggiators, even attached to the Slot Arpeggiator, which means you van add more, like notes, etc. By mixing and using intern sequencers modules you are able to mask notes, like on the NordLead3, to use more then 16 notes (any number you like) and even apply glides to some notes in the setting...
Alright, you have to read the Manual to understand, but thats no problem, I believe?
It's not all written there, but when you are going to think about the possibilities, you'll soon understand you are thinking about the most flexible synth ever...
Wout
PS Manual and a working softsynth demo (allthough without the Midi Out, of course, but the free Editor is also there, which has it all but the sound...) is down able at clavia.se |
Olsen
Posted: Thu Apr 12, 2007 5:42 am Post subject:
Answer to disrupt_the_mc |
Yes, i did try the Access Virus once and i stood quite impressed.
Is always a matter of consideration to get one, after all is so expensive as a NL, isn't it?
What do you know about the Alesis Andromeda?
I used to have the Alesis ION, have it for 4 or 5 months only, i didn't really like it much... i mean, is cute, some of its sounds are great but i don't like the interface and most of all i don't like the way that the bank of sounds is presented, you never find what you looking for and is very or totally unpractical; doesn't save properly; i know some people love the ION but i'm not in that club. I had enough of Alesis, i'm selling my QS8 after 6 years of being my master keyboard to buy a Triton, so i'm going to be without master keyboard for few days... good, i'll play guitars. |
Olsen
Posted: Thu Apr 12, 2007 5:49 am Post subject:
Replay to Blommers |
Yea, a lot of people recommends the G2 over the NL3; at this point the tentation to take action and trade my NL3 x a NLG2 is huge enough so my heart is open...
What do you think shall i do that?... or shall i keep my NL3 and get a G2 modular? |
TOTAL
Posted: Thu Apr 12, 2007 8:13 am Post subject:
Still curious, could NL3 be recreated on Modular? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Apr 12, 2007 8:23 am Post subject:
Re: Replay to Blommers |
Olsen wrote: | What do you think shall i do that?... or shall i keep my NL3 and get a G2 modular? |
Hard to tell, I think...
I have both, but the G2 is much more a challenge then the NL3.
At the other hand, the NL3 is a dead platform and the G2 is still in (a little) development.
Wout |
Olsen
Posted: Thu Apr 12, 2007 11:36 am Post subject:
It seems that the G2 has a lot of midi conveniences but what about the sounds? are they very different from the NL3?
and what about the filters and oscilators? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Apr 12, 2007 1:49 pm Post subject:
TOTAL wrote: | Still curious, could NL3 be recreated on Modular? |
In a way... yes, but I never tried
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Apr 12, 2007 1:51 pm Post subject:
Olsen wrote: | It seems that the G2 has a lot of midi conveniences but what about the sounds? are they very different from the NL3?
I should say they don't differ that much.
Most important is the NL3 Unison and the interface! You can't re-create that NL3 interface on your G2!
Wout |
