g2 filter vs evolver mp3
Page 1 of 1 [9 Posts]
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Mar 17, 2007 8:11 pm    Post subject: g2 filter vs evolver mp3 Reply with quote  Mark this post and the followings unread
Someone asked for this a while ago ...
I took a 303 patch with a nord classic filter and added a xfade so it can route to the evolver filter ... the part which routes to the evolver filter also includes a feedback loop from the evolver filter thru a voice filter in the middle of the loop & back into the evolver filter
the mp3 start with the g2 filter, and then there is a lot of different settings from the evolver filter ... a boring patch but it illustrates the sounds you can get from the evolver ... if people want, I can post a better demo ...
http://electro-music.com/forum/post-111531.html#111531
comments welcome!
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Sun Mar 18, 2007 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool.
Smile
iP (Ross)
Housefly
PostPosted: Sun Mar 18, 2007 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
well this settles it then.
i was seriously considering an expanded Nord Modular G2 Rack and a Poly evolver rack.
i made my choice Very Happy
iPassenger
G2 patch files: 78
PostPosted: Sun Mar 18, 2007 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I got my g2 rack about month n half ago, n i have never had more fun with piece of kit n learned so much.
defo get one. I am gonna expand mine in due course but to be honest at mo, i have enuff on with it as it is.
iP (Ross)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Mar 18, 2007 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad this demo helped .. the evolver filter is quite evil, it has many sources of distortion (3) and filter feedback (2) - both of which add more character to the filter. I added my own filter feedback in the g2 for even more mayhem ...
it was a simple patch and some random stuff ... but the g2 filter at the beginning has res fully cranked -- in the evolver it is almost 100% and goes all the way ...
the evolver filter is more squelchy than the g2's and phatter ...
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Mar 18, 2007 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
That is a good combo indeed 4 slot G2 + 4 voice evolver -- too bad the poly evolver does not have 4 inputs tho Sad only 2, Confused
http://www.dsisynth.com/images/polyrear.JPG
http://www.dsisynth.com/Keyboard/rear.JPG
you'd think each voice should have it's own dedicated input since the poly must be based on the mono evolver but maybe not .. if it did hen you could run 4 mono signals from a g2 into 4 inputs of the evolver and each is routed to a different voice - & different filter ..
but with a poly you can at least use one of the 2 inputs in each patch in the evolver) so in essence two independent filters (a mono signal into each) and feed those and back into the g2..
you can aways buy 4 mono evolvers Shocked
ow well nothing is perfect ...
/Dasz
Housefly
PostPosted: Mon Mar 19, 2007 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, 4 mono evolvers Very Happy. i would do that if i wasn't so painstakingly searching for the most compact yet supreme powerful studio/computer set-up Wink .
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Mar 19, 2007 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
heh heh, yeah I was being sarcastic because of the 2 inputs and 4 filters in one box ...
/Dasz
glitched
PostPosted: Fri Mar 23, 2007 6:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Evolver has been the best purchase I have made in the last five years. It's so exciting; it's my centerpiece, despite me owning a g2 engine, Monomachine, Machinedrum UW, and MC-202.
I have the mono version and I can't imagine having three more voices. SO THICK!
