Scott Stites
Audio files: 96
Posted: Sun Apr 01, 2007 1:28 pm Post subject:
Triple Wilson SVVCF Subject description: A module of ludricous proportion... |
Last Tuesday night I finally finished wiring up my new Triple Wilson State Variable filter. Out of all of it, I only had two easily fixed switched connections, which was a tremendous relief. I designed it so it could be pulled apart and maintained, but, oh gawd, after three and a half days of solid wiring, the last thing I wanted to do was debug the #$%!!.
I've mentioned in other threads what a be-atch this thing was to build - five PCBs, twenty pots, thirty connectors all in a 2U wide by 5U tall module, but in the end, after powering it up and playing with it, it all was proven worth it. This module covers so much ground, I'll never be able to approach making samples showing its operation from all angles.
It's 'normal' configuration has the three filters controlled from three common control voltage sources (CV1, CV2 and KBD/V/Oct input). The BandPass filters from all three are summed to a mono output and also passed through a panning circuit for a stereo output, with a pan pot controlling the position of filters A and C while filter B stays fixed in the center. The module is designed so that the each filter can can also be controlled and routed individually. All outputs are available so any configuration of all three can be applied to the mono and pan outputs and/or routed externally to the nether regions of my synth (I love the nether regions). Resonance is voltage controlled or manual. Each filter's resonance can be controlled manually or all three can be controlled by the resonance CV. When a CV is applied to the resonance control input, the manual master resonance control is converted into a bipolar attenuator (attenuvertor) the applies the CV to each filter, which is added to the intial resonance value of each filter.
Here is a sample of the filter in its 'standard' configuration IE, the three bandpass outputs. The signal is taken from the mono output. Last night I dusted off the Model 2 Klee breadboard to drive it. I played with it a little before I went to be. This morning, I powered it on, and found that the Klee had randomly volunteered a pattern that sounded better than the one I was playing with when I shut the system off. So, I just recorded it as it was, and, well, here it is.
The patch is two pulse VCOs - one is controlled by the 'A' output of the Klee, the other is controlled by the A+B output. A triangle LFO is applied to the CV1 input of the TWSVVCF, and EG is applied to CV2 of the TWSVVCF. Output B of the Klee is applied to the KBD input of the TWSVVCF, which controls all three filters.
The envelope generator's gate signal is generated by the output of Gate Bus 3, the trigger is derived from the clock trigger output of the Klee Gate Bus. The envelope generator is also controlling the VCA the signal passes through before it goes to the Lexicon delay and then on to the recorder.
I have the keyboard controlling one of the VCOs in addition to the Klee, but I really only moved the sequence down one step and back up once or twice throughout the sample.
As the sample progresses, I leave the individual filter cutoff controls fixed, I just adjust the level of resonance, the amount of LFO applied, the amount of EG applied, and the master initial frequency control. In parts I alter the level and invert the triangle signal applied to filter B with the CVB1 control, and do the same to the filter with the EG signal by adjusting the CVB2 control.
Here is a pic of patch, with the SVVCF module sitting next to the breadboarded Model 2 Klee. Notice the Klee schematic - I hadn't touched the breadboard since last November, and I had to re-familiarize myself with what was where....
Now, I have to take a certain Igor, lab assistant, to the park for the day for a well-deserved romp on the swing set and slipper slides and to feed the occasional duck.
Scott
Description: |
Triple Wilson SVVCF and Model 2 Klee Breadboard |
Filesize: |
116 KB |
Viewed: |
27359 Time(s) |
Description: |
Triple Wilson SVVCF driven by Model 2 Klee |
 Download (listen) |
Filename: |
tripsvc_klee.mp3 |
Filesize: |
2.68 MB |
Downloaded: |
2050 Time(s) |
_________________ My Site Last edited by Scott Stites on Mon Aug 20, 2007 2:58 pm; edited 1 time in total |
toppobrillo
Joined: Dec 10, 2005 Posts: 766 Location: oakland, ca
Posted: Sun Apr 01, 2007 2:25 pm Post subject:
nice, i've made 2 of these pcbs myself [not yet built tho]. did you make any changes to this circuit, or build it part-atim? |
Posted: Sun Apr 01, 2007 3:01 pm Post subject:
Re: Triple Wilson SVVCF Subject description: A module of ludricous proportion... |
Scott Stites wrote: |
Pretty much what I did today too
Nice filter. very 'glassy' like. _________________ ACHTUNG!
Scott Stites
Audio files: 96
Posted: Sun Apr 01, 2007 4:54 pm Post subject:
Topp, I left the filters unmodified, but I didn't use all of the components because everything was more or less going through the audio board, I put the output resistors on there and also combined the control voltages andu audio signals into composite signals before they went to the audio boards, which meant I didn't have to use all of the input resistors/caps.
I did use a TL074 in place of the TL084. For the filter OTAs, I used LM13700s and for the resonance OTAs I used LM13600s. I have many more LM13600s and would have gladly used them everywhere, but a comparison between them and the LM13700 as the filter OTA sounded to me like there was much less thump with the LM13700.
Scott |
Scott Stites
Audio files: 96
Posted: Sun Apr 01, 2007 5:16 pm Post subject:
Hey Tom,
So that's what 'glassy' means (I've always wondered about that term of description for a filter). In this mode, the filter can go from very subtle to very agressive - it's particularly good for doing formants and resonant metallic sounds. In the series mode, two LPs in series makes a wonderful, warmer type filter. HP->LP can just really be crazy. Another stunt it does fairly easily is to patch all three outputs of a single filter into the panner/mixer and make a really agressive notch, then the output of that can be patched to the inputs of the other two filters.
I'll have to do a stereo sampe - the pan circuit pretty much emulates the same thing found on the MaM resonator - its again a different, more spacial sound (all three outputs aren't concentrated in one 'field'). Modulating the filters antiphase with that makes some great swirly filter stereo stuff. It could be added pretty easily to Fonik's resonator.
Yes, today was just a perfect spring day in Kansas, and we're usually alotted only one before the wind picks up, so Igor (AKA Matthew or Mattchuck or Matthew the Merciless) and I had a blast.
Scott |
Posted: Mon Apr 02, 2007 1:37 am Post subject:
Scott Stites wrote: | Hey Tom,
So that's what 'glassy' means (I've always wondered about that term of description for a filter). |
Well not really- that's only my interpretation of it. Others may say that it sounds 'watery'?  _________________ ACHTUNG!
zipzap
Posted: Mon Apr 02, 2007 2:01 am Post subject:
Quote: | This morning, I powered it on, and found that the Klee had randomly volunteered a pattern that sounded better than the one I was playing with when I shut the system off. So, I just recorded it as it was, and, well, here it is.
how nice! like stuff like that.
very cool sounding filter! _________________ http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines |
Scott Stites
Audio files: 96
Posted: Mon Apr 02, 2007 6:55 am Post subject:
Tom, maybe it's frozen watery . I recorded a knock-off in the three-eyed exotic dancer vein last night using two LPs in series and the third filter configured as notch, which would probably qualify as more carbonated watery. It was late and I never converted it to MP3.
ZipZap - it sure makes me want to get around to building the Klee. Problem I have is that I still don't have anything to mount it in. My supply of Teflon (r) wire has pretty much dried up, too. I've told myself I'm going to mount my three VCOs, and possibly a fourth (a CGS I built but never tested), then move on to the Klee. Then, sometime after that, the SN-Voice. First I have to rig another power supply. This TWSVVCF really sucks the juice. And, I need to add another set of rails.
Scott |
Posted: Tue Apr 03, 2007 3:17 am Post subject:
I only have to turn my back for a second and you're up to some other shenanigans aren't you Scott!?
I don't feel like I've even had time to scratch myself lately!
(and I'm still getting in trouble for that! ) _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Tue Apr 03, 2007 11:23 am Post subject:
That's probably because you've been so busy chairing the worlds largest reptile and amphibian skin lingerie company in the world (see the Klee thread).
Scott |
Scott Stites
Audio files: 96
Posted: Fri Apr 06, 2007 11:16 am Post subject:
I've created a composition of sorts to better demonstrate the filter, well, at least in it's default 'triple resonant' mode.
This sample uses the VC Res and, on occasion, the stereo outputs.
It starts with a multi-tracked session using my Lexicon delay as a sort of impromptu looper - some of the tracks (particularly the pulsed VC res track) comes from the stereo output. The filter is modulated by an LFO, so you can, on occasion hear the frequency based panning going on - basically if it pans, that's it (I didn't do any manual panning while mixing down).
That part segues into a multi-tracked choir-like sound, which was done by recording a note, changing the formant a bit by adjusting the filters, and layering that on, ad-nauseum.
That portion segues into a very slow Klee sequence with some VC res pulsed..uh...resonance layered in (some from the stereo output - you'll hear it panning).
That portion segues into a single take of a Klee sequence with with two VCOs going through the TWSVVCF, one controlled by the Klee, the other controlled by the keyboard, with the Klee calling the shots on the filter. The filter is set for high resonance, and comes out as sort of a exotic mid/far east drum-like accompaniment.
The pan circuit could be used with the Fonik Triple Res, though in this composition, I'm mostly pulsing the res to self oscillation and back. I don't think the resonator is self-resonant (except for maybe Tom's(?)). Doesn't matter - it's just this example that's using self-oscillation. Any signal passing through gets the treatment.
The layered choir-like sound should be quite easy for Fonik's resonator to do - just tune it to a vocal sound, record it, change the filter settings slightly, layer that on, etc. etc. etc. Or, build about 20 of them, get twenty oscillators and.....well, you know.
Scott
Description: |
Composition using Triple Wilson SVVCF |
 Download (listen) |
Filename: |
amourpheous.mp3 |
Filesize: |
7.29 MB |
Downloaded: |
2091 Time(s) |
_________________ My Site Last edited by Scott Stites on Mon Aug 20, 2007 3:03 pm; edited 3 times in total |
Posted: Fri Apr 06, 2007 2:30 pm Post subject:
Very nice, as always, Scott.
Beautiful music to wake up to.
I sat here with a coffee and closed my eyes for a little while.  _________________ What makes a space ours, is what we put there, and what we do there. |
Joined: Apr 03, 2004 Posts: 24451 Location: The Netherlands, Enschede
Audio files: 297
Posted: Fri Apr 06, 2007 2:45 pm Post subject:
Nice track indeed, worked well under dinner as well  _________________ Jan
Scott Stites
Audio files: 96
Posted: Fri Apr 06, 2007 3:01 pm Post subject:
Thanks, Jan&K!  |
Joined: Jan 31, 2003 Posts: 18247 Location: Durham, NC
Audio files: 225
Posted: Fri Apr 06, 2007 3:05 pm Post subject:
Very nice composition. I like it a lot. Beautiful sounds, well constructed. Bravo.  _________________ --Howard
my music and other stuff |
Scott Stites
Audio files: 96
Posted: Fri Apr 06, 2007 3:15 pm Post subject:
Thank you, Howard
Scott |
seraph
Editor
Audio files: 33
Posted: Fri Apr 06, 2007 3:56 pm Post subject:
after all these positive comments I had to listen and I must agree
nice composition  _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
toybox
Joined: Aug 03, 2005 Posts: 176 Location: chicago/peru,illinois usa
Posted: Fri Apr 06, 2007 7:01 pm Post subject:
Scott Stites wrote: | I've created a composition of sorts to better demonstrate the filter, well, at least in it's default 'triple resonant' mode.
Brilliant! Good work! _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Scott Stites
Audio files: 96
Posted: Sat Apr 07, 2007 7:54 am Post subject:
Thank you all again. I can only say I think my music has improved greatly (and hopefully continues to improve) since my exposure to this forum, and I mean that seriously.
Scott |
Scott Stites
Audio files: 96
seraph
Editor
Audio files: 33
Posted: Thu Feb 05, 2009 1:30 pm Post subject:
alien sireens I like it  _________________ homepage - blog - forum - youtube
Audio files: 225
Posted: Thu Feb 05, 2009 5:08 pm Post subject:
Yes, I like it too. Nice one.  _________________ --Howard
Scott Stites
Audio files: 96
Posted: Fri Feb 06, 2009 7:27 am Post subject:
Well, thanks, guys.
Do you suppose outer space sirens would be green? There were plenty of green gals in the original Star Trek..... _________________ My Site |
Tim Servo
Joined: Jul 16, 2006 Posts: 924 Location: Silicon Valley
