 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
as time goes by .... (part II)
TB2006
G2 patch files: 17
PostPosted: Wed Apr 11, 2007 4:59 pm    Post subject: as time goes by .... (part II)
Subject description: cs80
I wanted to make more presets before uploading, but i do not have the patience because the first result is pleasing me already a lot.
This time, i think the CS80 sound really comes closer, although it should be loaded in fact as a performance with 2 identical patches.
Velocitysettings are such, that you really need a keyboard btw.
The wheel and wheel 1 are morphing sound length and sound volume,
the velocity morphs the volume and the filters, the pitch-stick morphs the filters too (and does not do anything anymore with the pitch).
each patch can be set to one of the 8 variants (against 12 for the cs80), and the second patch makes an identical synthesizer with variants, so the variations of both patches can make many combinations.
Patch A can be detuned, and the architecture is as close as i could to the real cs80 architecture (although the suboscillating sinus is a square in this patch).
The "suboscillator"=LFO tunes the VCO/VCF/VCA like the cs80 does, the next LFO tunes the pulsewidth and phase of the oscillators.
The nice thing is that the nord allows you to do most of it with the double oscillator, so it is voice-efficient! There are 10 voices when the two patches are combined to one performance.
it is surely still not perfect (and it is based on litterature and the arturia clone), but tmo better than my first attempt.
Hope you enjoy.
Tim
CS80 vs79-02.prf2
 Filename:  CS80 vs79-02.prf2
 Filesize:  8.07 KB
 Downloaded:  1731 Time(s)
