ian-s
Audio files: 42
G2 patch files: 626
cappy2112
Joined: Dec 24, 2004 Posts: 2503 Location: San Jose, California
Posted: Fri Apr 13, 2007 10:27 am Post subject:
Re: WAVE TABLE Subject description: from the AVR-X |
| g2ian wrote: |
I think at least one was done on a Nord modular because I can recognize the distinctive spectral oscillator shape.
(Take that, Clavia)
I wish I could talk with the developers to find out just what made them decide to drop this module or that module in the G2.
Not having a DSP-related background I can only guess. But I would expect that the choice of DSP hardware wasn't the issue, but that more of a manpower/time issue.
I could be way wrong though. |
Posted: Fri Apr 13, 2007 10:38 am Post subject:
Dr. Justice is one major DSP monster!  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
ian-s
Audio files: 42
G2 patch files: 626
cappy2112
Posted: Sun Apr 15, 2007 5:26 pm Post subject:
| g2ian wrote: | | cappy2112 wrote: | (Take that, Clavia)
What I meant to say was it looks like the spectral oscillator, or sine3 on the G2 shape oscillators.
The sample does sound different to the G2 though. The data is 8 bit with only 256 samples per cycle, but it sounds very 'good'. |
What did you use to make the image of the signal? |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sun Apr 15, 2007 6:03 pm Post subject:
| cappy2112 wrote: | | What did you use to make the image of the signal? |
I renamed the .bin files from the source distribution to .raw then added a 44100 8bit wav header using sox.
I could then load them into audacity to see and listen. The screen shot is just an audacity window.
I am thinking now it might be generated by an algorithm because the zero crossings line up on each cycle, which is not the case with the G2 shape sine3.
Alternatively, they might have doctored each of the 16 cycles to shift the zero crossing, which would add a little phase modulation. |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Mon Apr 16, 2007 1:13 pm Post subject:
Nice patch! Also very nice to feed some oscillator signal into the s/h input  _________________ Spinning at ~0.0000115740740741 Hz |
Falk
G2 patch files: 29
Posted: Wed Apr 25, 2007 8:38 am Post subject:
2 other ways to skin the cat |
Because the S/H is done at control signal time resolution you can still get small pops when the SeqCtr changes. Below are two ways to fix that. Both uses slightly more CPU though.
1'st version uses 5 S/H to make sure that the amplitude is changed only at the start of a waveform cycle.
2nd version uses glide modules to to change the amplitude gradually enough that no pops occur. By using different glide times for each harmony you can get some additional variation in the sound.
Really nice patch.
 Download (listen) |
| Filename: |
wav15_150_v1.pch2 |
3.45 KB |
| Downloaded: |
1543 Time(s) |
| 2:nd version with glide module |
 Download (listen) |
| Filename: |
wav15_150_v2.pch2 |
3.61 KB |
| Downloaded: |
1534 Time(s) |
Joined: Apr 03, 2004 Posts: 24580 Location: The Netherlands, Enschede
Audio files: 308
Posted: Wed Apr 25, 2007 3:48 pm Post subject:
Re: 2 other ways to skin the cat |
| Falk wrote: | | By using different glide times for each harmony you can get some additional variation in the sound. |
Indeed, I like that ! _________________ Jan
ian-s
Audio files: 42
G2 patch files: 626
Posted: Wed Apr 25, 2007 4:06 pm Post subject:
nice tweaks  |
